NOS Polk Cobra Speaker Cable
F1nut
F1nut Posts: 51,893
    txcoastal1 Posts: 13,514
    I have only seen them once at LSAF about 5 yrs ago, never got to see them in a rig. Here is a blast from the past thread by Madmax
    http://forum.polkaudio.com/discussion/19047/i-hooked-up-the-dreaded-polk-cobra-cables
  • [Deleted User]
    [Deleted User] Posts: 10,716
    there was a bunch on flea-bey for sale from UK I believe.
  • mrbiron
    mrbiron Posts: 5,721
    I confuse..........easily
    How are those cables terminated? It looks like someone jammed a paper clip in the end and sent some solder through it.
    I think someone needs to be these......F1 of "The original morning wood" F1's!
    heiney9 Posts: 25,487
    Those would be sweet! @$525.......that's too much to experiment with (for me). Nice to see them completely unmolested.
    billbillw Posts: 7,696
    edited June 2016
    According to Salvatore, to make these actually 'the best' you need to cut these down to less than 6' lengths (or shorter if possible) and run them 4-8 parallel. Lots of wiring/soldering. Very tedious.
    BTW, he says the 'flat' versions are not as good as the round. So, there ya have it. Interesting, but probably not worth $500+
    http://www.high-endaudio.com/RC-SpkrCab.html
    mhardy6647 Posts: 35,160
    edited June 2016
    All I remember is the horror stories of them (Cobra Cables, that is) cooking marginally stable amplifiers due (if memory serves) to their relatively high capacitive reactance :-)
    My ol' friend George* (first Polk Audio loudspeaker owner/user known to me... in 1976) bought & used a pair of Cobra Cables with his original (unsuffixed) Monitor Series Model 10 loudspeakers... and a GAS Son of Ampzilla amplifier, which didn't seem to mind them at all.
    * Not the late, lamented George Grand (of the Jersey Grands); another George.
    Toolfan66 Posts: 18,129
    As much as I would like to play with them, $500?? I'll stick with my MIT's..
