Stacking subwoofers ?
dekuda
dekuda Posts: 756
Has anybody here Stacked one sub on top of another sub ? Both being identical. If so, how did it sound ? Would it subtract from the bass? I am thinking stacking two Def tech supercube reference subs one on top of another. I would need to do this for space and I only have one corner in the room for a sub. I do not like them in any other area of the room..I have not gotten the second sub as of yet so I cannot try.
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
    txcoastal1 Posts: 13,514
    Stack them
    I'm not a fan of stacking anything , in a home environment anyway. I would think 2 subs stacked , in a corner, is going to overload that corner fairly easily. Plus I also imagine if your short on room, then the room isn't that big anyway, which also will make it easy to overload it.
  • Joey_V
    Joey_V Posts: 8,603
    Rel G1 are famous for being stacked.
    Joey_V wrote: »
    Yeah, but you have to have the room for it. Put everything into perspective, your average sized room full of furniture is not exactly ideal for stacking.
    msg Posts: 10,452
    This forum needs a "holy schnikees" reaction.
    txcoastal1 wrote: »
    tonyb wrote: »
    Not entirely true.....just that when we referred to something being "stacked" in my day, it meant something totally different. ;)
  • gce
    gce Posts: 2,158
    I'd say if you stack em you need to isolate them from each other somehow. With spikes or isolation pads or something. Thinking that would be hard to do with sub's so close together?
    Anaheim Hills CA,
  • dekuda
    dekuda Posts: 756
    Thanks everyone for chiming in . It sounds like it is 60/40 regarding not stacking. I would go with the def tech supercube reference since they have little vibration and a perfect square. My room is 15x20 ft with cathedral ceilings so I am not sure if I would be overloading the room. Its just that I have only one corner for these. That said, these are 1800 watt subs weighing 110 pounds each. With the weight and little vibration would I need anything more than some type of feet in between??? I have one and someone is tempting me with buying another one as is at $650... But maybe it may just be overkill. Though I have heard many times that you can never have too much bass :o
    HT System
  • JPete
    JPete Posts: 295
    Do it!
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • rpf65
    rpf65 Posts: 2,127
    Place one in the corner and the other on the coffee table. No more problems, except the empty end tables.
  • pkquat
    pkquat Posts: 748
    I would get both subs and give it a shot. The room sounds large enough. Center placement of subs, since you have two, or either side of the couch may also work depending on space and HT capabilities.
  • pkquat
    pkquat Posts: 748
    edited June 2016
    txcoastal1 wrote: »
    HT Pic
    ZLTFUL wrote: »
    HT Pic
    Be this guy...
    My, those screens are small :p
    edited June 2016
    ^^^^you could make a register on the Richter scale reports at the Advanced National Seismic System
    pitdogg2 Posts: 27,180
    I'm a fan of putting one front and back of the room to even out some bass modes. In my room they are in opposite corners front and back.
    tonyb wrote: »
    tonyb wrote: »
    and it wasn't the shoes:)
  • Joey_V
    Joey_V Posts: 8,603
    msg wrote: »
    txcoastal1 wrote: »
    yep i agree!!
  • dekuda
    dekuda Posts: 756
    So, I can pick up a mint deftech supercube reference for $650 and have two. The placement would be the problem. Maybe sell or trade the reference for a supercube1 and stack the two like a pyramid and maybe make a buck. I think it is good price for the reference. And I have my anitmode 8033 to equalize them.
    HT System
  • mikeyb128
    mikeyb128 Posts: 2,885
    I have bought gear too many times I didn't have room for. And trust me, I made it work and made it fit. Thankfully my girlfriend is easy going and has her head in the clouds most days :lol:
    I would say do it before it's too late. The anti mode is awesome. I've successfully calibrated 3 subs with one. It's a great little unit and I regret selling mine. Wish I kept it in the closet for just in case.
    2 channel:
    Theater:
  • dekuda
    dekuda Posts: 756
    mikeyb128 wrote: »
    Yeah, you are right. Usually we make it work and if we don't get the stuff we end up regretting it. Thanks for the advice !!
    HT System
  • Geoff4rfc
    Geoff4rfc Posts: 2,907
    tonyb wrote: »
    tonyb wrote: »
    LOL, we must be from the same "Day", I remember the term "stacked" referred to a pair of incredible projectiles, or, "floatation devices", or, "Hey, can I have those for a minute.....or two?"
    Set up: 11.2 HT + 2ch
    Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
  • pearsall001
    pearsall001 Posts: 5,318
    How's about stacking bookies on top of the subs with proper vibration control. Reposition/recalibrate for ideal room placement. Would pretty much take the place of towers but offer better overall control. Just a thought.
  • pearsall001
    mikeyb128 wrote: »
    Yes indeed, that Anti-Mode is awesome. It's a game changer for calibrating subs to your room. Mine isn't going anywhere.
  • erniejade
    erniejade Posts: 6,321
    This might not help you but in pro audio, when I stack/ couple my EV subs, it does throw sound more evenly in larger rooms on top of the added 3db.
