common speaker problems?
gatsbybu
There was a party at my house and my speakers were a bit abused - high volume, I think some drinks could've been spilled - regardless, one of the speakers isn't working - nothing whatsoever, not even a buzz - just dead. Are there common symptoms I should check first? I have RT600s.
Post edited by gatsbybu on
Double check all of your connections, both inside the speakers and out.
You might want to swap channels with your speaker wires to eliminate (or verify) the amp as the culprit.
I agree with da Picker.Political Correctness'.........defined
