SDA 3.1tl resto-mod
gwg_97
Picked up a pair of "well loved" SDA 3.1tl speakers for $200. Yuck, but sounds like a fun project. All the drivers were in place and in good shape except for pushed-in dust caps.
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Off with the end caps (which are glued in place). Used a hand sledge from the inside. Not too bad.
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded -
Built some new end caps with 3/4" mdf and made them flush with the cabinet using a router, trim bit, brads, glue, and good old bondo. Then I used a heat gun to remove the damaged black vinyl from the front and back of the cabinets.
With the side panels off the grills no longer fit flush with side of the cabinet. Time to break out the router again. I clamped the grill frames to the cabinet and cut them flush with the side of the cabinet using a trim bit and then did a 1/2" round over (as was used on the original grill).
What are you going to use to replace the vinyl? Nice job getting them cleaned up
Thanks! I'm covering all sides with raw cherry veneer.
Interesting choices, awaiting the finished product..... if I was going that far with the reveneer, I would choose a inlaid magnet system for the grills so that the ugly ball joint system was replaced. meniscusaudio.com/grille-fasteners-c-108.htmlHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
They're going to be beautiful, and a very unique pair for sure.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Dennis Gardner wrote: »Interesting choices, awaiting the finished product..... if I was going that far with the reveneer, I would choose a inlaid magnet system for the grills so that the ugly ball joint system was replaced. meniscusaudio.com/grille-fasteners-c-108.html
I would second this idea, when the Cherry Veneer is finished, you will always want to leave the grills off when listening, just to admire them.
I also like the way you have trimmed the top caps and grill frames to be flush with the cabinet, I never really like the slight over-hang either.
Looking forward to the finished product, I'm betting your new 3.1's will be gorgeous!
Great project. Very nice work. Looking forward to seeing them when you are finished.
Very nice!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Looking great.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Awesome idea with the cherry veneer, Will you be updating the electronics too? Looking forward to the finished product. Good luck and good sound. You will be a happy camper.
Looks amazing.
I have a set of 3.1s that I will look to revive one day as well. I wanted to refinish the caps on mine due to water damage. I know that the endcaps on the 3.1s are not the "removable" type like on the 1.2s and 2.3s. I thought about trying to build that functionality into mine once I take the caps off - like you've done with making it flush but then putting the caps on top of that. However, I wondered if the slight change in volume on the speaker interior would somehow affect the sound at all. I figured they were built with a certain volume in mind, and if basically putting in two sheets of plywood on the inside would somehow alter things. Maybe someone can answer that - or you can once they are up and running. They do look pretty amazing though. Don't know if I have the skills at this point to do what you're doing. Wish I did.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
Great idea to use the magnets but unfortunately I already used the Titebond II iron-on method to glue the veneer down. I'm happy withe results but the veneer ended up splitting a bit (not a big surprise). I will do the Crossovers, dynamat, RD0198s, etc. after the cabinets are done. Sonicaps on the high pass and either sonicaps or a less expensive set of caps on the low pass (daytons?). Any suggestions?
It's been fun so far and having the right tools and Google is a huge help!
Definitely the nicest pair of 3.1s I've seen, simple, eloquent. The slab top and bottom with wrap-around grill cloth is old hat. Add some nice spikes, or even outriggers with spikes, running front to back. Excellent work.Home Theater/2 Channel:
GospelTruth wrote: »Looks amazing.
I did this very thing to my 3.1TL's, the original caps were trashed so I added a new base (recessed inside the cabinet) for replacement caps to be glued or bolted onto.
The new cap in place
I also wondered about the internal cabinet volume dimensions that was displaced by the new "cap bases" that I installed, I installed the new top and bottom bases on both cabinets.
I think they sound wonderful and wouldn't concern myself if I were you!
I would stay with Sonicaps throughout, you don't want to have any "what if's" with this beautiful set of SDA's!!!
All the work is certainly IMPRESSIVE!!"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Nice!!!!
Mike Reeter wrote: »I did this very thing to my 3.1TL's, the original caps were trashed so I added a new base (recessed inside the cabinet) for replacement caps to be glued or bolted onto.
Awesome! Thanks for the reply and glad to hear your thoughts on what impact the new caps have on the overall sound. I'll probably go that route then when I get around to restoring the ones I have. Of course, looking at the creativity with the 3.1TLs in this thread could make me want to try something else.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
GospelTruth wrote: »Mike Reeter wrote: »I did this very thing to my 3.1TL's, the original caps were trashed so I added a new base (recessed inside the cabinet) for replacement caps to be glued or bolted onto.
Ha!, yes gwg_97 has me daydreaming about a "Winter Project"
Get 'er' done MikeMike Reeter wrote: »GospelTruth wrote: »Mike Reeter wrote: »I did this very thing to my 3.1TL's, the original caps were trashed so I added a new base (recessed inside the cabinet) for replacement caps to be glued or bolted onto.
Are you taking measurements by any chance? I am not sure anyone would ever want to do scratch built cabinets but it would be nice to have accurate measurements just in case.
Hey everyone! Thanks for all the comments! I got a few coats of Daly's Profin on them over the weekend and that's it. My Dynaco had some magic sparks on Saturday
and I was really busy.
I think I'll build some outriggers for these guys ASAP (great suggestion). Also, I'd be happy to take some measurements if anyone is interested.
If your lazy like me (which given what your doing is doubtful) there is a company that MAKES outriggers so you'd just need to install them. May save you time later on.
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Fantastic choice with the cherry veneer!2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
I am interested in having measurements. Thank you
I'd LOVE to see pictures of the finished cabinets!
my 3.1TLs
I will fix your shifted magnets for free.
Update, I have about 5 coats of Daly's ProFin (wiping varnish) on them now. I need to wait about a month before I can do a "hand rub" with a 2000 grit Abralon pad. If all goes as planed, they should have a nice satin finish when I am done. Time for the crossovers, dynamat, etc.
I'll post measurements/dimensions tonight.
