LS70 or LS50? Replacement Driver Model?
hagmanm2
hagmanm2 Posts: 205
edited June 2016 in Vintage Speakers
Hi all, I have a pair of LS70 or LS50s... I guess I need to figure that out first. I've noticed a slight distortion coming from one of the drivers. You can see that one of these drivers was probably already replaced as the 'dome' section is smooth unlike the original drivers that have the raised design (both of the drivers on the right speaker have the raised design as well).
TBH, I don't remember if is' the replacement driver or the original that has problems as it's been a few weeks since I checked it.
Anyways, can anyone tell me what specific driver I'm looking for to match the originals? Thanks!
Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
Post edited by hagmanm2 on
  • hagmanm2
    hagmanm2 Posts: 205
    Update: I should read my own past posts. These are LS50s - 6.5" driver. Anyone have a replacement and/or know the driver model I need?
  • ken brydson
    ken brydson Posts: 9,063
    Call CS, they have them. 800-377-7655. Tell them you're a forum member for a discount and free shipping. Last one I bought was like $48 IIRC
  • leftwinger57
    leftwinger57 Posts: 2,917
    I was never into the newer models of the Polk lines. Can't help there but why are there 2 different dust cover designs ? I found these in central Jersey C/L and still can't tell if the d/c are changed out. The LS50s or LS70s
    8n4bq-5612216429@sale.craigslist.org
  • hagmanm2
    hagmanm2 Posts: 205
    edited June 2016
    is the dust cover and dust cap the same thing? IE. The oval dome in the middle of the driver?
    I'm not the original owner so I'm not sure if the previous owner replaced one of the drivers or if it came like that from the factory. Seems like they'd all match from factory since they were all installed at the same time, even if the dust cap changed in future iterations of the same model driver
  • ken brydson
    The one without the embossed dust cap is a replacement.
