Binding Post Nuts for 80's Monitor Speaker
Funny stuff guys! If you can't laugh at yourself, your missing out on life...
Your no fun Russ. Here I am waiting for a good a-- kicking
Maybe next time
Because I am The Pumpkinking
Just gaining your trust before I turn you out, Pman...
killing me...bahahahaha
How about a teflon/plastic or non-conductive nut? How does that impact sound quality? Is the teflon non-conductive nut going to sound better than the plastic non-conductive nut?
Perhaps the non-conductive nut provides 'clear transparent sound'. -
^^had to stir the pot, just couldn't help yourself, right?^^Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Yeah...I need to just stop you are correct. I am disengaging there is no reason to stir the pot it will have no appreciable result.
Nuts, and bolts, and posts, oh my.............Home Theater/2 Channel:
dhsspeakerservice.com/
