Press test on SRS 3.1TL
I am finally putting my 3.1s back together and tried the press test on one of them. Pressing and holding the PR causes the MW drivers to extend for about 2.5-3 seconds as they return to centered. Is this adequate? By comparison my Monitor 10s stay extended longer than 10 seconds. But of course there are a lot fewer drivers and penetrations in the 10s.
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Best Answer
    F1nut Posts: 51,962
    Answer ✓
    10 seconds!?! Unless the vents in your drivers are somehow blocked that simply isn't possible.
    3 seconds at the lower end to 5 seconds at the top end is the range.
Answers
  • honestaquarian
    honestaquarian Posts: 3,258
    Are there any air leaks in the cabinet?
    That should answer your question.
  • jimbo1421
    jimbo1421 Posts: 772
    Correct me if I am wrong, but I think that there is always some leakage through the drivers. But how much is tolerable? How does one track down leaks? Spraying soapy water around the speakers while pumping the PR doesn't seem like the best technique.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    There are vents? Where do I look on the 10s to see if they are blocked? I have one pair of 10As (Peerless) and a pair of 10Bs (formerly with SL-1000 tweeters).
    As for the 3.1s, they see to be just below your press test spec. Perhaps the Armaflex will settle in with time.
    Thanks for your help, F1nut.
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 51,962
    The pole of each driver is vented through the dust cap.
  • jimbo1421
    Thank you, F1nut
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
