Press test on SRS 3.1TL
jimbo1421
I am finally putting my 3.1s back together and tried the press test on one of them. Pressing and holding the PR causes the MW drivers to extend for about 2.5-3 seconds as they return to centered. Is this adequate? By comparison my Monitor 10s stay extended longer than 10 seconds. But of course there are a lot fewer drivers and penetrations in the 10s.
Jim
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
Best Answer
10 seconds!?! Unless the vents in your drivers are somehow blocked that simply isn't possible.
3 seconds at the lower end to 5 seconds at the top end is the range.Political Correctness'.........defined
Answers
Are there any air leaks in the cabinet?
That should answer your question. -
Correct me if I am wrong, but I think that there is always some leakage through the drivers. But how much is tolerable? How does one track down leaks? Spraying soapy water around the speakers while pumping the PR doesn't seem like the best technique.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
There are vents? Where do I look on the 10s to see if they are blocked? I have one pair of 10As (Peerless) and a pair of 10Bs (formerly with SL-1000 tweeters).
As for the 3.1s, they see to be just below your press test spec. Perhaps the Armaflex will settle in with time.
Thanks for your help, F1nut.
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
The pole of each driver is vented through the dust cap.Political Correctness'.........defined
President of Club Polk -
Thank you, F1nut5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
