Dared SL 2000 Tube Pre Amp FS
  • Faustin
    Faustin Posts: 1,151
    Glad it arrived safely. Fire that baby up and let us know your thoughts
  • WagnerRC
    WagnerRC Posts: 2,207
    Would anyone have a manual for the unit or know where I could find a download? I've checked obvious places with no luck. Thanks
  • voltz
    voltz Posts: 5,384
    edited May 2016
    I have one, I try and get the scanner going...been awhile..
    Does not really say much, just the normal talk and warnings.
    I sent you a pm with grey-scale photos.
    Post edited by voltz on
  • WagnerRC
    Thank you so much. I really appreciate it. Have a great day.
  • WagnerRC
    oh boy got this puppy hooked up to my M6si. I may have opened a can of worms here. This is very impressive I must say.
  • hochpt21
    hochpt21 Posts: 5,423
    WagnerRC wrote: »
    Awesome to hear. Pretty sweet isn't it?
    What tubes ya got in there now?
  • WagnerRC
    Looks like 12at 7 and 5z4gy
  • WagnerRC
    just found a Brimar, time to swap it in
  • daboyz
    daboyz Posts: 5,207
    ^^^^Good plan!^^^^
  • Faustin
    Hey Bob. I packed the manual with the pre. I forgot to put it in the original box, so I put it in the outer box. It was in a zip lock bag.
  • WagnerRC
    found it, Thanks.
  • Faustin
    Good deal. Glad you found the manual. I started to panic when I saw your post and thought that you may have accidentally pitched it. That Brimar should do you good. Probably will not get much better than that. Try the 5Y3 as well for comparison. The 12AT7's will be fun to roll. Try the ones I sent you and then maybe if you can find some black plate RCA's, Mullards, even some Sylvania's, and?? Have fun and enjoy!
  • Nightfall
    Nightfall Posts: 10,083
    Holland made Amperex is where it's at for your 12AT7 slots.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • hochpt21
    And some Telefunken 5965's
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited May 2016
    Love the tele's, also the Siemens are fantastic as well. Loved my little dared. Had it with a Parasound HCA 1200 and they were a match made in heaven. Congrats and enjoy!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • voltz
    voltz Posts: 5,384
    Also Snow sent me some Amperex 7062's. I hadn't heard of them before but they sound great so what little research I've done I found comments like -> once you heard the Amperex 7062 you may never use 12AT7 again B)
    The are long bottle looking tubes.
  • WagnerRC
    pittdogg this is the other unit.
    heiney9 Posts: 25,482
    Many times the longer plate tubes in the Dared are microphonic. Not every pair, but several. I did tame some of the offensive long plates like the Tele 5965 and Amperex 7602 with Herbie tube dampers.
    I also used the Pangea Pico sorbethane feet on the Dared to cut the vibration going to the unit. Both helped cut the microphonic tubes. There's just too much gain.
