Tips for Improving your Home Theater
Hi Everyone,
Audioholics just posted a great video on their top 10 tips for improving a home theater.
Tips include:
1. Check connections - speaker wire polarity, right cables used, etc.
2. Speaker positioning - check locations, eliminate obstacles blocking direct path of sound.
3. Speaker configuration - check your bass management settings and channel assignments.
4. Speaker calibration - check your levels using an SPL meter -slow, c-wt.
5. Seat optimization - positional EQ, move seats away from back or sidewalls.
6. Source Setup - make sure your Blu-ray or Cable box is set to pass bitstream audio, shut off dynamic compression.
7. Display calibration - get your TV out of torch mode, properly set black levels and color temperature.
8. Improve room acoustics - padded throw rug for tile floor, drapes on windows, absorption if room is too reverberant.
9. Improve room lighting - darken windows, doors to cut light and improve contrast ratio of your display.
10. Add cool props, movie posters or pros, pop corn machine, fridge.
Are there any other tips you live by for your own setup?
  • mikeyb128
    mikeyb128 Posts: 2,885
    11. Make sure it's loud enough that the dogs run out of the room.
    2 channel:
    Theater:
    EndersShadow Posts: 17,729
    12. Add backlighting (example) to TV to help with eye strain....
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited May 2016
    13) Get an SVS Subwoofer or
    (14) 2
    Garage | Polk Monitor 5B's
    Go to the movie theatre and forget all that stuff. lol
    Pretty basic stuff mentioned, I would think most do just about all those things anyway if possible.
  • Mikey081057
    15) Use a small refrigerator as an end table so you don;t miss anything
  • rooftop59
    rooftop59 Posts: 8,120
    16. make sure you can see the TV from the can. #realmancave
    this list is stupid.
    Game Room 5.1.4:
    Bedroom 2.1
    16A. Forget 16 and hand out empty buckets for use as needed :smile:
    Have Hooter girls as sound absorption panels. Betcha you start watching a heck of a lot more movies.
  • polrbehr
    polrbehr Posts: 2,854
    tonyb wrote: »
    Yeah, movies. Yeah, that's what I was watching, a movie. Uh huh.
    That's a silly idea anyway, Tony. We all know they would only add reflections and
    bounce... B)
  • Nightfall
    Nightfall Posts: 10,083
    rooftop59 wrote: »
    To some of us but I guarantee members have passed through these "halls" that didn't know half of the OPs list.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,072
    PolkTeam wrote: »
    Yep, ignore pretty much anything suggested on that site.
  • vmaxer
    vmaxer Posts: 5,121
    PolkTeam wrote: »
    Me too, most of the time they are way off.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    gudnoyez Posts: 8,174
    Great Idea beers within an arms reach, perhaps a toilet nearby where you leave the door open without missing a thing, thus eliminating hitting the pause button at all.
  • Emlyn
    Emlyn Posts: 4,844
    Tame room rattles when using a good subwoofer. Use Blu Tac to prevent picture frames from rattling and falling off walls and your spouse's precious knick knacks from falling off of shelves and smashing on the floor. Turn up the bass.
  • lightman1
    lightman1 Posts: 10,797
  • Mikey081057
    gudnoyez wrote: »
    Or a bed pan nearby with a window to throw it out of
  • Willow
    Willow Posts: 11,288
    Adult Pull ups they absorb matter and probably some sound too.
    Remove all clothing......the wife might appreciate your sack bouncing around from the low end rumbles......the kids will most likely start looking for a retirement home to put you into.
  • tonyb wrote: »
    Remove all clothing......your sack bouncing around from the low end rumbles......
    Is this how you set the subwoofer/LFE channel when the receiver has no bass management?
    I actually like the idea of lists of this type. I would include an explanation of the differences between the subwoofer settings and LFE trim.
  • mrbiron
    mrbiron Posts: 5,721
    Lists shmists......set receiver to "max" and enjoy.
    As for the scat movements. Install garbage disposal in sofa a la Kramer style.
    Lightman has it right...mo beya!
    *mic drop* Boom!
  • ken brydson
    ken brydson Posts: 9,046
    mrbiron wrote: »
    Lists shmists......set receiver to 11 and enjoy.
    Fixed it for ya...
  • mrbiron
    mrbiron wrote: »
    Fixed it for ya...
    My receiver goes to 12....one louder.
    mrbiron wrote: »
    mrbiron wrote: »
    Fixed it for ya...
    posted on behalf of @ken brydson
  • mrbiron
    Ken and i have an unspoken bond.
    We are connoisseurs of humor. He would never treat me like that.
    Homey don't play that!
