RCM KIT!
Wanted to pass this along. Bought this RCM KIT from Nick in canada (canfab3d.com) great guy to deal with, we'll built kit and Nick is very helpfull. Works as stated (if not better). Built my own plenth and bought a used wet vac (20.00) from CL. Did a fantastic job on all my very good to mint records, totally eliminating all pops and clicks and background noise (dead quiet now) I have a collection of vintage vinyl ( bought new by me back in the early to mid 70's) all were not in condition to be listened to due to the noise and pops and clicks in them. After cleaning them they are now very good and play wonderfully with only a few spots where noise is still noticeable (will try recleaning to see if they can be improved any more but at this point I'm very satisfied with the results on even the worst of them so far. The cost(of the kit) has been paid back just in the resurrection of just a few of these "vintage" albums. This is the best bang for the buck I have seen in the market for RCM'S. Again no affiliation but very satisfied with this unit.uoxsdl5pu3rg.jpg
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Hey, @soundfreak1,
    Very nice work!
    And a very nice story. You make me very sorry that in 1989, when I decided to go digital, I gave away my record collection, and I only recently gave a friend my vintage AR turntable.
    I'm glad this project worked out so well for you.
  • MrBuhl
    MrBuhl Posts: 2,419
    And it looks great too! Nice work!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • soundfreak1
    soundfreak1 Posts: 3,414
    Hey, @soundfreak1,
    Very nice work!
    And where was I when all this took place? LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    msg Posts: 10,465
    Fantastic job! I think I'm going to try using a higher powered Shopvac next. I deliberately went with a smaller lower powered one having heard that too high suction could be problematic, but since you're getting better results than I am, I'm gonna give a shot to following your process!
    I agree, bang for buck ratio on this setup is great, and +1 to Nick. That guy's a real pleasure to work with.
  • soundfreak1
    On the wand is a "air flow control" valve check its position and adjust as needed.Your vac should have plenty of strength. Could be the contact time, rotation speed, ect. I go 2 rotations in each direction in the clean and in in the rinse phase. Also the wetting agent used is a factor as well. I found a source for "triton x100" which was recommended to me as well as 99.9% isopropal (25% in solution) RODI water (from highend salt water coral breeder and store (75% solution), the x100 at 2 drops per gal. Makes a full gallon of solution. I flood the record with solution and wait 10/15 sec and then scrub in both directions all the way around then vac it up. I do the rinse the same way.I will admit that on the worst of albums in my collection so far only a little noise remained. Maybe a second cleaning will release the rest of the dirt on the more stubborn ones? The design (wish I'd thought of it) is simple and effective. What surprised me the most was the audible difference in my "mint " albums! They were dead silent in the run in, between songs and run off sections and most important no audable background noise just clean music. I'm pickled tink. Plus very satisfying to build the plenth and do the plumbing (alias my version of his (Nick) original design not mine). It's also nice to share. Went to a friend's house Saturday and had a vinyl cleaning party complete with music, beer, comradery and.... All had a large time!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    gudnoyez Posts: 8,174
    Looks sweet does Nick provide everything but the plinth, or do you got to make a trip to the plumbing departmentioned at the home Depot? Do you have the dimensions for the plinth, and did you just use a hole saw to mount the piece that holds rhetoric suction part in place. Nice job.
  • soundfreak1
    Almost,yes,yes,and yes, thanks
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited May 2016
    He (Nick) provided all but the PVC elbows and the wood (18x18x3/4) and the feet. Did use a hole saw and the feet came from his source (on Web site) wood was Cherry hardwood veneer on 3/4" ply . Side banding was real cherry as well. I basically just retrofitted his original plenth design mk1 with his mk3 kit. Came out ok. Works great. A lot of fun to build.Thanks again.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    As a follow up on the cleaning of the ooold albums.... they came out so much better than I could have hoped. Of the 50 or so I considered "unlistenable" 30 or so have been returned to my "everyday rotation" as they sound very good now. Still a little noise one would expect from vinyl. The rest are still being worked on. It's amazing the effect that a good cleaning can do.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    msg Posts: 10,465
    I've been meaning to post up with some feedback with the SCVRCM. I spent Sunday morning/early afternoon cleaning a bunch of stuff and noticed that older records, in general, seem to clean up much nicer than some of the newer stuff I have. I get varying results with the new stuff. Some of it's great, after, but some of it, I don't know could be pressed in, and also some surface muck isn't coming off, so thinking, maybe enzyme or something.
    Also, I'm completely spoiled to clean records now, so much so, that when I see new oe records coming out of the jacket, I really just can't get over how littered a lot of these albums are with scuffs, muck, and paper or cardboard bits. It's really neat to clean a record, flip it, and noticed just how dirty it really was before the cleaning. I wanted to try to post some before/after photos, but it's difficult to detail the stuff that you can remove in a cleaning process like this, you know, since you kind of have to view a record at a certain angle to see the condition.
    Definitely spoiled.
  • soundfreak1
    This is the finished (almost) cleaning station. Cart is temporary until I fund one a little larger and proper finish and color. But it allows me to roll it into area to use more easily. vnup816udeev.jpg
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    msg Posts: 10,465
    man, you look like you're ready to offer cleaning services at audio shows :)
  • soundfreak1
    Lol, I was thinking of a card table at the end of my driveway. I did have a lemonade stand when I was a kid. Same idea.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • muncybob
    muncybob Posts: 3,265
    Very nice looking set up! Can you give us an idea on how much total money you have into it?
    Yep, my name really is Bob.
  • soundfreak1
    About 60.00 including everything except the kit.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Looking like you are a pro. Mine is on the way Nick must of sent it off as I got a Canada Post e-mail today with tracking # I ordered a couple of goat hair brushes for the cleaning and rinsing cycles where did you get your squeeze bottles? I'm going with the 80% Distilled 20% Isopropyl and either a couple of drops of dawn or the dishwasher drying agent for my cleaning mixture. I even got one of his Zerostat holsters hope to be cleaning Vinyl early next week. I will probably retire the ol Spin Clean.
  • soundfreak1
    Bottles came from "Michaels" a craft store.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Just found squeeze bottles at Target, and just ordered 2 goat hair brushes a bottle of Clearaudio Stylus cleaner and a 50 pack of Okki Nokki inner sleeves off of Audio Advisor. I'm looking forward to my latest passion cleaning Vinyl the right way to bad I'm OCD I see some late nights ahead of me.
    msg Posts: 10,465
    Hey Steve, did you ever get your Okki Nokki goat brush and the rest of the RCM cleaning stuff?
    I'm curious to hear how these goat brushes work out with wet/RCM cleaning.
  • StevieB
    StevieB Posts: 257
    Does anyone use tergitol for a cleaning solution? It's pretty inexpensive but sounds like it really needs a lot of rinsing.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
    SCompRacer Posts: 9,121
    Nice work! Long live DIY!
  • Thanks
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    msg Posts: 10,465
    I was just shopping surfactants/detergents and settled on Triton X-100.
    What kind of recipe are you looking at?
    StevieB wrote: »
  • StevieB
    StevieB Posts: 257
    msg Posts: 10,465
    Just checked that out. Interesting; just add to water.
  • msg wrote: »
    Don't "just add water" you need to use a "PURE" water or you will be leaving residue of minerals and other nastys on your records.. I use RODI water and this will leave no residues. This is important!! Also some surfactants are not allowed to be sold to private individuals (crazy laws)
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    msg Posts: 10,465
    oh. dehr, yes, I presumed everyone would know this meant distilled water.
  • msg wrote: »
    I meant no slight just some may not realize the importance or difference.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    msg Posts: 10,465
    oh, none taken, and I agree - it needed clarification for kb purposes.
  • StevieB wrote: »
    Working great for me. I do put it through 2 rinses. Using my Spin Clean brushes. Got the squeeze bottles for under a buck in the baking section of Walmart supermarket. Set up in the bathroom connected to my listening room (second floor "princess" suite)pfk1r9zamddx.jpg
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
