Proper SDA functionality, tests?
2
  • tugboat
    tugboat Posts: 393
    I think part of the out of place sounds comes from the artificial separation applied during mixing. That and out of phase vocals drive me crazy.
    Driver carries only 20 dollars in ammunition
    Pedestrians have the right of way, unless they are in the way
  • TennMan
    TennMan Posts: 1,266
    TennMann, I have more than 5 feet to my side walls and I don't have a crazy wide sound stage, nor do I have sounds coming from behind me. My room is well damped, zero echo when clapping hands. In fact, I've never had those wild effects in any house I've lived in with any of my SDA's. I can't say I've ever heard that from SDA's in others homes either. When I read people describe those effects I think to myself that their room must be really bad because that is not how SDA is supposed to sound.
    It sounds like your experiences with SDAs is similar to mine. It's good to know I'm not alone. :)
    @Gunther16, My room is far from ideal. The area behind the fireplace is an open foyer that probably is bad for sound, plus the room is too live. The room by design is a compromise for 2 channel listening, watching TV, and serving as a living room. It's part of downsizing for retirement.
  • Gunther16
    Gunther16 Posts: 243
    Did not mean to be critical, I was just noticing things that may be the culprit to your issue and giving some ideas. No one in a real world living environment has the ideal room/environment (well maybe a few do) so compromises have to be made.
  • honestaquarian
    honestaquarian Posts: 3,258
    Gentkeman please do not forget what the OP was asking about HIS situation
    We have kind of highjacked this thread and taken it off course.
    I offer my humble apologies to the OP
    Please read the first post everyone.
  • xllr8
    xllr8 Posts: 17
    Nice to see a lively discussion, re: these speakers. Apparently they can be fickle in regards to their placement & performance.
    Repositioning seemed to help balance out the soundstage & bring a slightly better center focus. I do however have a moderately reflective room.
    Again, as for the "smear': I think I realize what I was hearing. It seems that center positioned audio tends to be quieter than panned audio. I am however always referencing studio monitor sound (in my head), & they tend to have laser like positioning. That being said, these speakers do seem to bring me a step closer to that sweet sweet magic.
    I'd like to test the circuits, as per the SDA handbook, but I'm not sure I saw specs for an SDA2b... Thoughts/experience?
  • Schurkey
    Schurkey Posts: 2,122
    When it matters to me--like when I set-up a system in a different location, or set-up a new system--I rely on one or more Stereophile Test CDs. This gives me tracks with left-only, right-only, both channels in-phase, channels out-of-phase, frequency bands, and many more. I can identify placement, driver, and cable-connection problems quickly and efficiently.
    Strongly recommended. Test CDs 1, 2, and 3 seem to be available only as a package for $30.
    http://store-badz031c.mybigcommerce.com/
  • lawdogg
    lawdogg Posts: 469
    Did Polk ever publish the reference factory test to verify SDA functionality?
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
    F1nut Posts: 51,934
    Yes they did. If Trey still has his site up it's posted there. VR3mods.com
  • xllr8
    xllr8 Posts: 17
    Schurkey
    exactly what I had in mind, some reference audio. I think I've got one lurking somewhere; must dig.
    F1nut
    Looks like VR3mods. is still up poking around it now.
  • xllr8
    xllr8 Posts: 17
    Schurkey
    Turns out I don't have my Chesky with me, but I found http://www.audiocheck.net/audiotests_polaritycheck.php
    & NOW I can CLEARLY hear what is keeping me from enjoying these speakers. The out of phase versions of the audio (where some types of 'stereo' effects lie) just scream, in comparison to the in phase stuff.
    Can I run try these speakers SDA-2Bs without the interconnect? After the scare with the difference signal test I'm skeptical to make any changes that might blow up my amp.
    I'd like my "phantom image" back directly in front of me, instead of breathing right next to me on either side (unless it was mixed that way of course). B)
  • xllr8
    xllr8 Posts: 17
    Schurkey
    So, I tried them without the interconnect, to hear what the speakers themselves sounded like (in my current room & amplifier). I'm thinking it's time to move on; a little too spitty in the highs & veiled in the vocal body range for my current setup. It was nice have room filling smooth low end for a change, though.
    Thanks for all the help & pointers. Just wish they weren't so damn heavy; they are pretty though.
  • Nightfall
    Nightfall Posts: 10,083
    SL2000 tweeters? They're shite. I went from Peerless to SL2000's and it was disappointing, to be honest. The new replacements, RD0194's that can be bought from Polk, are smoother and less bright.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,934
    I take it you mean all the sound coming from in between the speakers. The problem there is live music doesn't sound like that. SDA gets much closer to the sound of live.
  • honestaquarian
    This is the review that myself and @tugboat were referring to that f1nut says that no one else but me has read. @Heiney9 also posted this review on another SDA thread.
  • Schurkey
    xllr8 wrote: »
    Schurkey
    I don't know what you mean by "scream", but this sounds to me like you have polarity problems. The out-of-phase sound should be diffuse and hard to localize. The in-phase sounds should be easy to "find".
    xllr8 wrote: »
    Again, that seems "off".
    xllr8 wrote: »
    They shouldn't sound a bit different in the low-end with or without the cable. There's something wrong, we just haven't figured it out yet. Loss of bass with the cable attached again suggests an out-of-phase component in the acoustics--a driver wired backwards, or some other fault.
    Don't give up. YOU HAVEN'T HEARD THESE SPEAKERS YET. You've been hearing the defect, and the defect will be fixable.
  • xllr8
    xllr8 Posts: 17
    Sorry for the confusion. The in/out phase tests check out, but the out of phase... seems louder. There is no loss of any kind without the interconnect, just a little less "lively".
    Another test for Center, Mid Left/Right, & Left/Right, & Offstage was the most telling. The results put Mid Left/Right in the speakers & Left/Right as wonky as Offstage.
    Again my reference for phantom image is studio & single driver setups (nothing fancy). This is an admittely "narrow" window into the musical experience, but it's the most reliable entry point in to what the mix engineer was hearing & mixing for, in my experience. Did a short stint as an audio engineering student/studio tech.
    If anyone in Portland is interested. They check out by the quicktests, but just seem to be causing me more headaches than smiles.
  • xllr8
    xllr8 Posts: 17
    ...or shoot! Feel free to come have a listen if you're in the area. 4 ears better than two?!
    F1nut Posts: 51,934
    And yet the official owner's manual clearly states, "Distance "S" should be at least 3 feet."
    Deal with it.
  • tugboat
    tugboat Posts: 393
    I bet the "S" distance noted in the manual was a compromise so people with smaller rooms would still purchase the speakers as it is the shortest distance with minimal impact. In a perfect world, space wouldn't be an issue and the manual would most likely state 5 1/2'.
    Nothing to deal with. More information is better. Just because you don't like it, doesn't invalidate it.
    F1nut Posts: 51,934
    It's got nothing to do with whether I like it or not. It's what the manual says and it's been the suggestion around here since I joined. IMO, it's far better to say at least 3 feet so that people understand that is the minimum distance.
  • honestaquarian
    It says right there in that review by Stereo Review magazine that Polk Audio says the distance ideally should be 5 1/2'. Obviously everyone (including myself) cannot do that because of space restrictions. It also says right there in that review that they heard sounds coming from beside them on some program material. Must have been a bad room or something ;)
    F1nut Posts: 51,934
    Yep, too close to the back wall, too close together and seating was too far away.
  • Gunther16
    You are all beating a dead horse. Placement is confounded by room size, experimentation is a must as is compromise. I would suggest using the minimum of 3' suggestion if possible (not possible in my case) and go from there experimenting with distance to back wall, distance apart etc. and find the best spot then leave it alone. Just saying.
  • tugboat
    tugboat Posts: 393
    Gunther16 wrote: »
    Exactly. I cannot get more than 2 1/2' from the side walls, but the width of the soundstage is amazing and so is the depth. Now it might not be perfect, but no other speakers I've owned have come close to the sound from these puppies.
    heiney9 Posts: 25,492
    edited May 2016
    If you can't set-up SDA's properly to get the maximum benefit, then don't blame the speaker if it sounds poorly. That goes for anything.
    Perhaps one should have done some research first or perhaps now it's time to move on to something that isn't so compromised and will fit into whatever your situation is.
    I was aware of what SDA's needed to perform their best and my set-up is based on those requirements.
    Not everything is going to work for everyone in every situation as intended. Not the fault of the product as there is a plethora of info about SDA's and how they need to be set-up to get maximum advantage of their unique properties.
    Simple as that, really.
    P.s. All this whining about lack of room size and not being able to move them far enough apart or sit far enough away is not the speakers fault. Do some research before you buy things.
  • lightman1
    lightman1 Posts: 10,797
    I set mine in the front yard and pull up lawn chair and a cooler. Talk about spatial desperation and impact dynamics and other big words and phrases that confuse me and confound the neighbors!
  • xllr8
    xllr8 Posts: 17
    edited May 2016
    Thanks for all the spirited discussion; this passion led me to further experimentation with much more agreeable results.
    The biggest factors I can point too, ...distance & pairings (Marantz over Harmon). NOW there is a strong front & center, with consistent beautiful stereo expansion.
    Now, if I could I could just figure out what happened when I disconnected the negative terminals as per the SDA handbook. (In the quicktests section).
  • teekay0007
    teekay0007 Posts: 2,288
    Hopefully a silly question (like the one in your TV manual's troubleshooting section that first asks, "Is the TV plugged into an AC socket?") for the OP: Do you have the speakers set up so the one labeled as "Right" is on your right-hand side, when you are facing the front of your speakers? Something mentioned above (probably what lightman1 said! :p ) brought this question to mind.
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2016
    teekay0007 wrote: »
    I have actually set mine up wrong before. :disappointed:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
