How should 1.2TLs appear on spectrum Analyzer
Answers
    F1nut Posts: 51,798
    tugboat wrote: »
    tonyb wrote: »
    How do you think they should look ? Most here don't use them so that may be why you aren't getting the answers you want.
    Your question is like asking how should x receiver sound. There is no right answer because it all sounds different to different people. How a speaker looks on an analyzer and what that means will be very different for people.
    So I ask you, how do you think the 1.2's should look ? Do you have a baseline to reference how they should look to see if your off ? Is there even such a thing aside from the manufacturers data taken in special room to measure these things ? If so, who's baseline and how was it obtained ? Do you think another's baseline would offer the same results in your room on your system ?
    You measure frequency response to get rid of, or accentuate certain "in-room" responses....and to what pleases your ears. How the 1.2's look, or measure in another person's room and preferences has no bearing on yours. Thus makes those spectrum analyzers a nice light show, but not much use for anything else plus they add noise to the signal which most try and avoid....hence why most don't use them and why your not getting any answers.
    Not trying to be a putz here, but it's not the forum's fault your asking questions about a piece of gear hardly anyone uses anymore let alone with 1.2's.
    Since SDA works by canceling crosstalk, I was wondering if this would also affect the results of measuring them. If they can make a sound disappear to my ear, could it also do it to the mic/analyzer.
    A mic is a single receptor while our ears are 2, so I do not think the crosstalk cancellation would be of a concern.
  • tugboat
    tugboat Posts: 393
    As a side note. What does it matter why I'm doing this? People do lots of things just because. Why try an AC power cord that cost hundreds of dollars? Why try silver path cords? Why angle in your SDAs to hear the effect when the manual clearly states not to? Why try modifying the base your spikes sit on?
    Curiosity is important. If there's something you want to try, why not? It might be low or nonexistent on someone else's list, but that doesn't make it a waste of time or effort.
    Driver carries only 20 dollars in ammunition
    Pedestrians have the right of way, unless they are in the way
  • K_M
    K_M Posts: 1,632
    tugboat wrote: »
    K_M wrote: »
    tugboat wrote: »
    tonyb wrote: »
    Where and how was the mic located, when you measured?
    Was it up really close, or at one meter, or way back in the room? and was it at the height of the tweeter that plays full range?
    The mic was in the position my head occupies when listening. It's about 6' away and 4' high. It was slightly angled upwards towards the drivers.
    Pointed towards the speakers I would assume?
    Centered between the speakers, you will lose the upper octave sounds somewhat, as they are off axis a good bit.
    Have you tried it at say one meter and in line with the tweeters?
    That may be more accurate as far as the uppermost octave goes.
  • tugboat
    tugboat Posts: 393
    K_M wrote: »
    tugboat wrote: »
    K_M wrote: »
    tugboat wrote: »
    tonyb wrote: »
    When the mic comes back from being tested, I'll give that a try.
  • K_M
    K_M Posts: 1,632
    [/quote]
    When the mic comes back from being tested, I'll give that a try.[/quote]
    And try with just one speaker playing.
    heiney9 Posts: 25,447
    SDA is a timing thing, not making things disappear. Think of it in the simple terms of making things arrive in the correct order.
  • K_M
    K_M Posts: 1,632
    heiney9 wrote: »
    Good point.
    This thread really explains it well.
    http://forum.polkaudio.com/discussion/166073/how-does-sda-work-with-a-pin-blade-ic
    Ken did a great job of making it sound simple!
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hi tugboat,
    Your question is certainly valid and deserves a reasonable answer. I've sent it to the person who, if available, can certainly give a meaningful response. Why don't we all take a few deep breaths and calm down a bit.
    No need to be quite so terse.
    Thanks, Ken
  • JPete
    JPete Posts: 295
    Great way to close a thread guys...
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • vmaxer
    vmaxer Posts: 5,120
    Here's the reply from Matt Polk:
    "Ken –
    In general, never trust results from an analyzer, like the Audiosource, that shows only full-octave bands. You need at least 1/3rd octave resolution. The other big problem is that this type of measurement doesn’t distinguish between what the speaker is doing and what the room is doing. Since lower frequencies bounce around the room much longer than high frequencies this type of measurement will always show much more mid and low frequency energy than high frequency energy. Making meaningful measurements in a normal room can be done but not with that piece of equipment.
    Then there’s the problem of SDA. It’s very difficult to get measurements on the SDA’s that have any relationship to how the speakers should sound. This was always a problem with reviewers who would use their standard measurement techniques and get strange results which sometimes influenced their reviews. The 1.2TL’s are especially hard to measure due to the number of different drivers and tweeters all covering different frequency ranges. Then there’s the SDA stuff which is still doing something even when the interconnect isn’t connected. We used a dummy head with mics in the ears to make measurements using a B&K FFT system but only as a guide. The final voicing was done by ear and this is what counts.
    What makes the SDA’s unique is that they work the way our ears work. Microphones don’t. If you tried to design an SDA speaker based on microphone measurements it would sound horrible. He found this out when he tried equalizing the speakers according to what the Equalizer was telling him. Experimentation is always a good way to learn something!
    -msp
    Cheers, Ken
    Wow, from Matt Polk!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,798
    I stand corrected about the mic.
  • tugboat
    tugboat Posts: 393
    Couldn't ask for a better answer.
    I posted this link already.........see the 1st page of discussion
  • honestaquarian
    honestaquarian Posts: 3,260
    Yes I see that
