JB Weld, where to put it!
Can someone upload a picture of exactly where you place the JB Weld? Want to make sure I'm doing this right! Thanks in advance.
  • trj
    trj Posts: 320
    Just dont put it on your food :smile:
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • Gatecrasher
    Gatecrasher Posts: 1,550
    I can think of a couple other places I wouldn't want to put it.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2016
    There are pics and diagrams on this thread on magnet repair. The pics are hard to see as they used Loctite Clear instead of JB Weld. forum.polkaudio.com/discussion/comment/2224925#Comment_2224925
    Apply a bead of Loctite/JB Weld where the front plate meets the magnet, and where the back plate meets the magnet.
  • boston1450
    boston1450 Posts: 7,758
    See this magnet. Im gonna put a bead on each side (this is a cerwin vega 15)ln42vy5loeww.jpeg
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    Randy-Maine
    by David WMG
  • HzTweaker
    HzTweaker Posts: 959
    This is very good information. I don't know how I missed the bit that instructs you to apply to the rear plate. I'm sort of aggravated at myself because I only applied between the front plat and the mag. . Is it possible for the rear plate to shift?
    F1nut Posts: 51,769
    Yes
  • HzTweaker
    Well it looks like I've a good Sunday project ahead of me.
