Denon dvd 2900
I picked up a Denon 2900 at salvation army for $15. It plays regular cd's great but being unfamiliar with SACD was unsure if anything special needs to be setup with the unit to try one out. Thanks for helping out an SACD novice.
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • lightman1
    lightman1 Posts: 10,797
    edited April 2016
    Will you be using a 2ch pre or integrated? Or feeding it through an AVR?
    Couple of scenarios for different set ups.
    I used to own one. Solid unit for its age.
    And you STOLE it!! ;)
  • MrBuhl
    MrBuhl Posts: 2,419
    Great player - I have often considered one - that is a STEAL for sure!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • StevieB
    StevieB Posts: 257
    lightman1 wrote: »
    Yep for $15 I had to snag it, but just kind of assumed there were probably issues with it, to be at S.A. I only have a 2 channel set up, P5, with the cd player to outboard DAC via coax.
  • DaveHo
    DaveHo Posts: 3,582
    You'll need to use the analog connection for SACD or DVD-A playback. Those formats are not output via the digital connections. You should hook that puppy to a TV so you can verify the settings. If you're using it for 2 channel only there are some you might want to change. Make sure it is set to play the DVD-A layer not the DVD-V layer if you'll be spinning some of those.
    Also be aware they are known to have issues with the laser pickups. The one used for SACD is different than the one for Redbook CD, so you might find it has trouble reading one, but not the other.
  • lightman1
    Dig it. You could really have fun through the 5.1 outs to an AVR. A lot of SACD have that. Fun to listen to when you're sto....buzz, no.....had a glass of wine.!!!
  • StevieB
    StevieB Posts: 257
    DaveHo wrote: »
    Thanks for the info. I've got a little tv to hook up and go thru the settings. It's worth a shot, if there are issues with the SACD laser, it works well for reg cd's.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    SACD is the first function to go out on most universal players, so it may not work. I don't know why that is, but it happens to many of them.
  • skrol
    skrol Posts: 3,456
    My DVD-2910 played SACD and DVD-A just fine but was hit and miss for Red Book. All is good after replacing the pick-up.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • StevieB
    StevieB Posts: 257
    Does blue ray use the same laser as SACD? Trying to find a used SACD to try out is a **** here in Jax.
    pitdogg2 Posts: 27,173
    skrol wrote: »
    I have to agree with Skrol here on my 4 universal players I had they all stopped playing red book CD's before any of the other medias. drove me nuts.
    StevieB wrote: »
    NO!
  • agfrost
    agfrost Posts: 2,472
    My Marantz is fine for redbook and DVDA, but has given up on SACD. Hoping a laser replacement will get me back in business.
    Jay
  • skrol
    skrol Posts: 3,456
    Could also be alignment of the pickup is out
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • A steal indeed. I have a DVD-2200 that I used for CD's until a year or so ago. I recently reconnected it to use for music DVD's that I want to play through my stereo setup rather than my 5.1 system.
    Power Amps: Luxman M-02, Luxman M-2000, Luxman M-300
    Preamps: Luxman CX-100, Luxman C-1010, Luxman C-120A
    Speakers: Polk Audio SDA-2B's (no mods...yet), Klipsch KG4's (Crites Crossovers and Titanium Tweeters), Genesis 1's
    Digital Front End: Marantz CD6005, Denon DVD-2200, Fiio X5 II
    Headphones: Sennheiser RS180, Sennheiser HDR170 w/Fiio E12 Montblanc (home). Sennheiser HD449 w/Fiio E12 Montblanc (portable)
    EQ: SAE 180 Parametric
  • StevieB
    StevieB Posts: 257
    Well the **** thing is hit or miss aggravating and don't think it's worth getting it repaired but sure makes me realize how much I need a new CDP. I've read it on here a thousand times, but sometimes you just have to learn it for yourself, all transports don't sound the same! :#
    edited May 2016
    StevieB wrote: »
    Amen.....we have a word for that, it's called "experience", and you just got yourself some. ;)
    Sorry to hear about it not living up to your needs. Tell ya what, scout out a Pioneer AVI 59 or 79, universal players put have rock solid cd/sacd playback and on the used markets under 150 bucks or so.
  • StevieB
    StevieB Posts: 257
    skrol wrote: »
    That was the problem. Watched a youtube video of a guy that changed the laser on a similar denon and he gave some alignment guidelines and poof, been working great.
  • skrol
    skrol Posts: 3,456
    Excellent!
    Stan
    Main 2ch:
    HT:
    Other stuff:
    You have a link I'm interested to check it out.
  • StevieB
    StevieB Posts: 257
    He's got 3 videos, I believe he talks about adjusting in the 3rd.
    https://youtube.com/watch?v=to8ojRiBOag
    https://youtube.com/watch?v=v-5pBD_szbQ
    https://youtube.com/watch?v=iCFmxN6Vl1I
  • JPete
    JPete Posts: 295
    I picked up a Lexicon RT10 for SACD playback not long ago. I'm using it for redbook now too. Sounds really freaking good and mine was a steal, in my opinion, for what it's done for my system.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
