Anybody try this RCM out?
gudnoyez
http://m.ebay.com/itm/3D-Printed-Record-Cleaning-Machine-Bring-your-old-vinyl-back-to-life-/151903631006?nav=SEARCH
Seems legit and is half the price of the inexpensive Record Doctor sold at Audio Advisor, I've seen the video and it appears to work pretty good. If you already have a smaller shop vac you are set. I am considering this as a replacement for my spin clean without having to spend the dollars the VPI's and Okki Nokki's cost
Lots of love for it over on AK. The turntable is stout, if you don't require a cabinet and don't mind supplying a vac unit, it might be for you.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
http://forums.stevehoffman.tv/threads/100-rcm-record-cleaning-machine.457854/
Here is the thread I found out about it on one of the posts has the you tube footage you can watch, looks like it would do the job and very well.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Dennis Gardner wrote: »Lots of love for it over on AK. The turntable is stout, if you don't require a cabinet and don't mind supplying a vac unit, it might be for you.
Thats the best thing, I own a few shop vacs so I would be set, and until arthritis sits in the motor will always workHome Theater
Man, nice share on this. I'm curious now, as well. Would love to see what a vacuum RCM can do for listening quality, but can't quite get myself onboard with one of higher end recommendations yet. Everyone I've spoken with who owns a vacuum RCM swears by it; essential gear.I disabled signatures.
$100 plus a shop vac? Almost seems too good to be true. Either that or what the brand name RCM's cost are extraordinarily priced. Shop vacs are really loud, that's my only thought on a downfall. At least the Stanley one I have is really loud, are there quiet(er) shop vacs out there?
Thanks for sharing, I'll do some reading. If you get one please share your thoughts.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I checked out a VPI and honestly it was pretty loud, the best thing about this one if the vacuum wears out you just replace it, a $20 cost and the only part of your cleaning rig ya gotta plug in and turn on and off.Home Theater
I think that one of these mounted onto a hush box (heavily foamed, plywood) that had a remote switch would be ideal for $150 investment.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Vinyl, the final frontier...
I have the VPI 16.5 and its really loud!!! but I can not see being without it, the other cheaper alternatives should work fine as they basically work the same way, but the VPI spins it for you freeing up your hands for applying the cleaner and holding the cleaning brushes...2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
What about the lick and wipe on my pants method I use on my CDs?
I use the "Hot Breath, Pant Leg Spin" myself.....HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Don't they dissolve? -
Too weird I was literally just looking at this unit less than 5 min ago and considering ordering.LOL. any down side I can't see?Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I just finished watching the video - I think I'm going to give this thing a shot.
I'm going to order direct from Nik at http://www.squeakycleanvinyl.com/
I'll let you guys know if it does anything to remove jerk record shop owner juju, too.http://m.ebay.com/itm/3D-Printed-Record-Cleaning-Machine-Bring-your-old-vinyl-back-to-life-/151903631006?nav=SEARCH
Seems legit and is half the price of the inexpensive Record Doctor sold at Audio Advisor, I've seen the video and it appears to work pretty good. If you already have a smaller shop vac you are set. I am considering this as a replacement for my spin clean without having to spend the dollars the VPI's and Okki Nokki's costI disabled signatures. -
I ordered this unit from Nick the Canadian last week. Very polite, eh?
I need to find a place to find some cleaning brushes like the ones he has in this video below (any ideas where to source?) And some squeezy bottles for the cleaning fluid and rinse. I'll probably go with one of the cleaning fluid ree-sipes I've seen in some of the other posts I've seen discussion about here:- Record Cleaning Fluid Recipe - http://forum.polkaudio.com/discussion/171212/record-cleaning-fluid-recipe-rcm
- Record Cleaning Fluid - http://forum.polkaudio.com/discussion/comment/2222549
Ebay Listing - http://www.ebay.com/itm/151903631006
Demo video. Looks like pretty decent build quality.
https://www.youtube.com/watch?v=QbphnT1d-ysI disabled signatures. -
I will be getting this one also, but have to hold off a bit need to order a dust cover for a turntable that's in route. I believe I'm going to get the goat hair brush from Okki Nokki to go along with the canfab and order the record doctor concentrate cleaner which mixes with a gallon of distilled water. I plan on using the spin clean in conjunction with this for a distilled water only rinse after cleaning. Looking forward to your review on yours.Home Theater
The Spin Clean rinse sounds like a good idea.
Just checked out that brush. Interesting.
http://www.audioadvisor.com/prodinfo.asp?number=OKGHRCB
I was thinking the same. Using it in conjunction with the Spinclean would be a good idea. I'd probably do the Spinclean first and then the vacuum. The Spinclean actually brushes the LP with some force, I'd imagine that would dislodge anything better than just wetting with a very soft brush and then vacuuming?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
The only brushes I have used are the VPI ones you get with their RCM's, I have 3 I use one for each cleaner and 1 for the rinse.
http://www.musicdirect.com/p-7660-vpi-replacement-brush-for-16-series.aspx2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I don't think the Spinclean applies any more force than the brushes on my MiniPro truthfully, its the vacuum that makes the difference IMO. I will say I like my Spinclean for the really grungy stuff as a prewash (then I vac on the Minipro)
That said - I applaud the DIY in this thread for a vacuum machine, if I was handier I would have done it myself as well. You're going to get the same results at a much lower price, with maybe a little less inconvenience. (For instance the minipro brushes and vacuums both sides at the same time, or Darryl's note that automatic rotation allows free hands for brushing - both conveniences not to be underestimated!)
On a side note - Darryl, you make me feel like a slacker - three brushes for cleaners and rinse! I am SO lazy LOL!!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
but the 2 extra brushes set me back another $100
Yes the VPI turnes the LP for you but...
If you have never use the VPI then you don't know what your missing, if you don't know what your missing then you won't miss it!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
recently got a KAB, its a model ev1.
I use a hand steamer, then a spin doctor, then the kab with the vacuum cleaner to take it all off, so far so great, will report back.Post edited by scottyboy76 onhumpty dumpty was pushed -
Hey guys, got all my stuff together for the SqueakyCleanVinyl 3D Printed RCM from CanFab3D.
CURRENT KIT IS AS FOLLOWS- 1 - 3D Printed RCM Kit from CanFab 3D
- 1 - Cleaning brush (included with kit)
- 1 - Shop-vac
- 2 - Squeezy Bottle (500ml/~16oz); one for cleaning solution, one rinse | http://amzn.to/1Q1LAph
- 2 - Gallon Distilled Water
- 1 - VPI Record Cleaning Fluid Concentrate | http://amzn.to/1Q1LrlH
- 1 - 2 pack 99% Isopropyl Alcohol | http://amzn.to/1Q1LG05
FUTURE CONSIDERATIONS- I am thinking about removing from the 500ml/16oz squeezy bottle approximately 50-100ml (~1.5oz to 3oz) of the VPI mixed cleaning solution, and replacing with same amount of 99% Isopropyl alcohol (I will probably do this now, in fact, the more I think about it)
- I will probably add at least one additional brush to this kit/method, and possibly play around with a steamer.
- I will probably also experiment with a DIY cleaning solution recipe instead of the VPI concentrate, given its cost.
I also wanted to post up this link to Nick's site - he offers his plans for a full on stand-alone RCM Station for a more finished approach. You can purchase a more elementary kit from him, and source the other parts yourself for an even cheaper approach if you prefer a bit of DIY. Looks pretty easy, so this could be another option for any DIY'ers interested in building a full on station. If you don't need/want all that, then the turnkey tabletop kit (subject of this thread) seems to be a good option. I like this idea best at this point because it was the easiest way for me to get up and running, and you can set it up and take it down when you're done, and store it away in a tub or something.
http://www.squeakycleanvinyl.com/diy-rcm-instructions.html
I'll post up with my impressions of the 3D printed RCM after I get a chance to use it. Not sure that'll be today since I have some grown-up responsibilities to see to, but I do have a couple of dirty records that need some attention.Post edited by msg onI disabled signatures. -
Can't wait to hear your impressions, glad I started this thread. I have ordered my ginko cover it will ship soon, then record store day next Saturday, then ordering one of these from Nik. I would go with the VPI or other Concentrates to start out with and gather information on your on home mixture, but I assume SCompRacer has a well tested concoction of his own he could recommend. Get your adult responsibilities done and report backHome Theater
When you get tired of turning the record, you could always add the motor from an old ice cream maker. They have high torque and turn slow.
Just finished building this one using Nick's (3d from canada) used 3/4" cherry hardwood veneer. Stained with traditional cherry stain and 3 coats of Simi gloss poly
Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
nice! where'd you get your squeezy bottles? I went with the ones I linked above and they leak.
have you tried it out yet? I haven't gotten around to washing any yet, but just got a new album this morning from Discogs, and it needs a little attention.I disabled signatures. -
Got the bottles at "Micheals" craft store. Will start using today and tomorrow.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Just cleaned my first album (ARS ) with the RCM. Results were stellar as the album was unlistenable (if that's a word) before ,now like brand new album. Dead quiet. I'm sold!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
