AV Receiver?
fonso
fonso Posts: 7
edited March 2012 in Electronics
Hey guys. i currently have a csi a6, rti a3's and have a pair of fxi a6's on the way. I need to upgrade my receiver and i was wondering if you can give me any ideas. I am hoping to add on a pair of rti a7's later. So i was thinking of a 7.1 set up with a av receiver with pre outs so i could add an amp latter when i have to. Any suggestions?
Post edited by fonso on
  • Geoff4rfc
    Geoff4rfc Posts: 2,835
    edited March 2012
    Hey Fonso, I'm very new into this electronic world and learning all the time (hopefully). I'm still with my original receiver choice at just two years.
    I feel that I made a great choice, and even though I didn't have the help of this forum at the time, I did an exhaustive search, first looking at what brands and models fit into my budget, and then the massive comparison and review process began.
    What I ended up doing was going for the most bang for buck item, and at that time, IMO the Onkyo 807 couldn't be matched for price point vs feature and performance.
    Ironically enough, due to lack of experience and ignorance, I knowingly got a receiver with pre-outs but seriously doubted I'd ever have a need for them, pre-outs for me was on the bottom of the list. Man am I glad my AVR has pre-outs.
    Back to long story short, my "suggestion" would be to gather your budget first, then see which AVR's fit into that budget, then start your comparison.
    Once you have it whittled down to a couple of units, I'm sure the board of professionals here can guide you off that cliff.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • chumlie
    chumlie Posts: 8,658
    edited March 2012
    For av recievers it always boils down to Pioneer Elite or Onkyo. Pick one and be happy. Do a search and you will see.
  • luhnk
    luhnk Posts: 34
    agree with Geoff4rfc, thought I got a good av receiver, it doesn't have pre outs, fff********cckk
    CSi A6
    RTi A5 x2
    PSW125
    RTi A1 x4
    Onkyo TX-NR646
    Sony PS4
    Sony BDP-S5500
    Monster HDP 2500
    Panasonic 60st50
  • rpf65
    rpf65 Posts: 2,127
    Think I would probably stay away from the newer Onkyo's. Read a while back that Accu-eq doesn't calibrate the front 2 speakers. Probably go with an older model that used Audyssey for calibration.
    If 4K content is important, than you'll need the newest versions with HDMI-2.0a and HDCP 2.2. If that isn't important go with an older model.
    May want to also tell us what you'll be using it for. For instance if music is important, as well as movies, I'd recommend a Marantz. On the other hand if you will be watching mostly movies, I would probably look at Yamaha.
    Then again, the higher end Pioneers will be able to drive the A 7's better than any reasonably priced AVR out there.
    Just saying a little more information will get you better advice. How much music, gaming, movies/tv use do you normally use your system for.
    tonyb Posts: 33,072
    Pioneer SC series or Yamaha Avantage series
  • I have about the same setup of speakers that you have but then I have the rtia9. I recently upgraded from a denon 3808ci to a yamaha cxa5000 paired with an adcom gfa7000. You can't really go wrong with either setup. I loved the denon but the yamaha with the adcom is in a league of its own.
    Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
    Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
    Stuff laying around. Too much to list but don't want to sell either.
  • cfrizz
    cfrizz Posts: 13,415
    Having speakers powered by a dedicated power source will always trump a receiver by itself.
    Make sure whatever receiver you get has preouts to add a separate amp.
    Welcome to Club Polk!
  • boston1450
    boston1450 Posts: 7,758
    edited April 2016
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
