Sticky Speaker Relay Sony Receiver - How to fix?
msg
msg Posts: 10,452
Hey guys,
working on an old Sony receiver I'm going to gift along with a set of old bookshelf speakers.
It's got some sticky speaker relays, I think. When I play music through it, sometimes only one channel comes in. If I tap or wiggle the relays, the other channel comes in.
If I wiggle the relays with music playing, the sounds will cut in and out, and sometimes affects the sound quality.
I was going to pull the board to have a look at the solder points beneath. I'm wondering whether they're intact. Is this the right path to resolution on this sort of thing? It also looks like I might be able to pop the cover off the relay? Like there's a small release tab at the bottom, near the board?
    msg Posts: 10,452
    The "loose" turned out to be just play in the cover/caps for the relays.
    I took the opportunity to practice some soldering kung-fu, and desoldered them, took them off the board, popped the caps for inspection, cleaned them, shot them with some canned air to dry, put them back together and soldered back onto the board.
    Still seems to cut in and out if I give them a good wiggle, but they seem to be working better.
    They looked pretty clean inside, and not gunked up. What happens to these things?
    I should have taken a photo, but in this design, there seems to be a vertical inductor at the back, with a switch tab sort of lapped over the top of the coil. When the switch is engaged, it pulls down the tab, which seems to pull in the contact legs to engage whichever speaker terminals are supposed to be active? Is that how these things work?
    msg Posts: 10,452
    I also cleaned the volume knob potentiometer, but it's one of those digital controls, not a real knob with stops. Is this still considered a potentiometer?
  • pkquat
    pkquat Posts: 748
    If you can watch the relays with the caps off, you can see whether the contacts are closing. If they are physically closing then it is probably the contacts / pads. Sometimes the relay contacts / pads can get iffy with oxide or dirt. Sometimes the pads can wear out and the relay needs to be replaced. If you cleaned them with deoxit or similar, and it did not help, then if there is space, a little bit of fine sandpaper can help, but if the contacts are already worn, this can kill them. I don't know about these specific relay's only relays in general.
    Its not a a real pot in a true variable resistor sense. Some volume knobs are a group of resistors with contacts that act like a pot. These have a stop and are more prone behaving like an old scratchy pot. Others are a group of contacts that tell another circuit to raise or lower the volume. These spin in circles. Sometimes these can have a dead spot, or don't read in certain positions, but are rarely scratchy. Both of these types can be usually be cleaned similar to a regular pot if the contacts are visible. The last type that I am aware of can spin in circles, however there are only two switches, or single double switch that picks up indents in the volume knob to tell which direction it is moving. This tells another circuit to raise or lower the volume. In this case the switch needs to be cleaned, if you can even see it or get to it to clean it.
    msg Posts: 10,452
    I missed this response, thank you for this information.
    I think the cleaning fixed it, but I've had it parked again for a while and need to give it another test before I send it off.
  • Greeting brothers and sisters. Im new here but i already find this group helpful. Im not actually a repairer, but through internet i managed to fix almost every household devices.I also have Sony Lbt-A590 with the same problem speaker relay.ive changed few relays and still no success. I once opened cab and closed pins handy,and i got sound.
    But Lol,i have to do after every powering off and on. How can i permanently bypass the relay at all.
    mhardy6647 Posts: 35,014
    edited November 2024
    Not a good idea to bypass the relay(s). It (they) is/are there for a reason.
    All electronic components operate using smoke (often referred to in the popular literature as magic smoke). If the relay is bypassed, and if there is a fault somewhere (typically in the power supply), the magic smoke required to operate the receiver will escape - you may see it. Once depleted of smoke, the receiver will not operate.
    In full disclosure: there are exceptions, e.g., in vintage automotive electrical systems from the UK.
    B)
    Where are you sourcing relays, @Herbicon ? Are you buying from a legitimate and established distributor (e.g., Digi-Key, Mouser, etc.)? If you're buying from eBAY, Amazon or other generic online sources... you may be getting junk relays! It's a thing, unfortunately.
    https://audiokarma.org/forums/index.php?threads/i-have-a-teac-a1250s-that-had-a-bad-relay-i-installed-a-new-upgraded-one-from-ebay-and-after-installing-it-it-tested-bad.1069584/page-4#post-17391538
  • daddyjt
    daddyjt Posts: 3,081
    Relays also offer critical protection for your speakers….
    ― Aleksandr Solzhenitsyn
    daddyjt wrote: »
    Good point! That they do.
    Loudspeakers also operate on magic smoke. Don't ask me how I know this. :#
    F1nut Posts: 51,772
    Herbicon wrote: »
    You need to replace the relay with a new one.
