? for all amp users
Willow
do you use a stereo amp or Ht amp ?and why
thanks
thanks
Post edited by Willow on
2 channel here, nothing else will do for music.Political Correctness'.........defined
President of Club Polk -
Ditto.Originally posted by F1nut
SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
I am headed for a Stereo only.......No need for all those speakers when two will do fine.............:)
also cheaper..........Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
thanks
no one is using an amp for HT or a stereo amp for HT with their receiver ? -
I listen to music 99% of the time so I use a 2ch amp. When it comes to HT, the rest of the speakers are powered by the H/K receiver.
Maurice -
Because, my main speakers deserve their own amp...yep yep- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
7 Channel Outlaw for the HT/Multichannel Music.
Antique Sound Labs Tube Amp for SDA/LSi 2-channel rig.
Seperate amps are generaly of a higher quality than the amps in a receiver, they don't have to share a power supply with the processing section, and they don't need to be upgraded when a new format becomes available. -
Four 2-channel amps power my HT. Three power the mains and center (bi-amp config.) and the 4th powers the surrounds.If...
Ron loves a film = don't even rent. -
Ron, you knucklehead.
You are bi-amping your mains and center.
Cheers,
I find that a good stereo amp is needed for smooth 2 channel listening. I think that quality is not as important to acheive good HT sound. Most receivers will do for HT only. That is why I put most of my equipment budget into the main 2 channels. Lesser so for the other 3.
Parasound 1500A for my Polks, Outlaw Mono for my center & my Denon handles the rest.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I'd have to disagree. Since all amps sound the same anyway why not use the same quality equipment every where?Originally posted by venomclan
(Pulls on flame proof underware and ducks behind the couch...)
Duh!!!:oIf...
I have both Stereo and Multi-channel amp. NAD C272 150w x 2 powers my Polk RT800i towers and the Adcom GFA-7605 125 x 5 powers the CS400i, FX1000 and RTi6 speakersl
Why?
If I just want to listen music or watch movies with 1 or 2 ch soundtrack I use only my NAD C272 and the Adcom GFA-7605 stays off. But anything more then 2-ch I use both amps. This way I'm more flexible. One of the main reasons I bought Stereo amp because I'm a 2-ch music listener and very serious about it plus NAD C272 is one of the sweetest soundingl amps available in the market. IMHO I believe that Stereo amps mainly designed for 2-ch music and performs very well because of there internal design and engineering compare to multi-channel amps whereas Multi-channels are primarily for HT but still work excellent for music as well. The best thing about separates beside better sound is that you have more flexibility, room for upgradebility than a receiver.
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
adcom here 7 channel amp love it it is supper. next amp is sunfire sig 7 400 wpc dual outs for mains it is real sweet.
I use 4 of the 5 ch's in Sunfire #1 to bi-amp my HT mains. No complaints here when I dial back to only 2 ch's. A quality HT amp can swing both ways.
That said, I also have asorted 2 ch's for 2 ch...More later,
Tour...
Vox Copuli
I use a outlaw 5 channel for both 2 channel and HT,
Will have to agree with tour here.....a good ht amp should be able to swing both ways...
that being said, I have never messed with a dedicated 2 channel system.....or tubes for that fact.Polk LSi 15 Fronts
Polk LSi C center
Polk LSiFX Surrounds
Outlaw Audio 990 Pre/Pro
Outlaw Audio 755 amp
Paradigm PDR-12 Sub
Outlaw Audio Cables
BetterCables Cables -
I currently have a 6 channel amp. (only 4 channels are currently working)
I wanted something that could drive any speaker I choose to try and run as my HT expands. At the time I had LSi15s running and due to space and location contraints found the 7's with a sub run and look better than the 15's for HT. (When I get a larger room, will run SDA 1c's in the front (already own) and 7's in the rear.)
I also am married with children and wanted something easy to run. (imagine the phone call - no sound from the center channel, look for lights from the 3rd amp up from the bottom on the second shelf.......)
For my needs, this is a great setup so far. (but really need a better sub - hey, I already have the amp for it.....
Two amps here. 5 channel amp runs the center and surrounds. 2 channel amp runs mains in stereo and ht configuration.
Ditto. -
i'm using the processor on the avr8000 with 7 channel stereo for music and thx dd ex for films(dual dsp).the avr8000 amp section is bi-amping the fronts and center.and the avr525 is bi-amping the surround, and amping the surr back and the center.avr525, avr8000, two pa2000
four RTI10
csi5
six s36II jbl
two m80 axiom
two dvc punch3 rockfordfosgate
AnD a PrOuD OwNeR Of 7 M200 OuTlaW MoNoBlOcKs -
Hi Willow,
I'm using a two channel Carver TFM-35x 250X2 for my main speakers in a HT set-up, with my receiver powering the center, and surround speakers. The carver is 2 1/2 times the power of my receiver. It's cleaner it opened up the front two speakers, and gives them much more detail than the receiver did. I listen to more music than movies, and really enjoy the sound from the power amp.JmasterJ Polk to the Death -
I use two channel amps for my two channel rig, and my home theater rig. Why? Cause that's what I want to do.
George Grand (of the Jersey Grands) -
Gee thanks George next time don't be so detailed..:cool:
That's NOT the road to a great, vintage receiver deal...More later,
Tour...
Vox Copuli
