? for all amp users
Willow
Willow Posts: 11,257
edited October 2004 in Electronics
do you use a stereo amp or Ht amp ?and why
thanks
Post edited by Willow on
    F1nut Posts: 52,002
    edited September 2004
    2 channel here, nothing else will do for music.
  • dcarlson
    dcarlson Posts: 1,740
    Ditto. :D
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • PolknPepsi
    PolknPepsi Posts: 781
    I am headed for a Stereo only.......No need for all those speakers when two will do fine.............:)
    also cheaper..........
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • Willow
    thanks
    no one is using an amp for HT or a stereo amp for HT with their receiver ?
  • organ
    organ Posts: 4,969
    I listen to music 99% of the time so I use a 2ch amp. When it comes to HT, the rest of the speakers are powered by the H/K receiver.
    Maurice
    VR3 Posts: 29,549
    Because, my main speakers deserve their own amp...yep yep
  • Frank Z
    Frank Z Posts: 5,860
    7 Channel Outlaw for the HT/Multichannel Music.
    Antique Sound Labs Tube Amp for SDA/LSi 2-channel rig.
    Seperate amps are generaly of a higher quality than the amps in a receiver, they don't have to share a power supply with the processing section, and they don't need to be upgraded when a new format becomes available.
  • Ron-P
    Ron-P Posts: 8,520
    Four 2-channel amps power my HT. Three power the mains and center (bi-amp config.) and the 4th powers the surrounds.
    If...
    Ron loves a film = don't even rent.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Ron, you knucklehead.
    You are bi-amping your mains and center. ;)
    Cheers,
    Russ
  • venomclan
    venomclan Posts: 2,467
    I find that a good stereo amp is needed for smooth 2 channel listening. I think that quality is not as important to acheive good HT sound. Most receivers will do for HT only. That is why I put most of my equipment budget into the main 2 channels. Lesser so for the other 3.
  • cfrizz
    cfrizz Posts: 13,415
    Parasound 1500A for my Polks, Outlaw Mono for my center & my Denon handles the rest.
  • Frank Z
    I'd have to disagree. Since all amps sound the same anyway why not use the same quality equipment every where?
    (Pulls on flame proof underware and ducks behind the couch...) ;)
  • Ron-P
    Ron-P Posts: 8,520
    Duh!!!:o
    If...
  • hamzahsh
    hamzahsh Posts: 439
    I have both Stereo and Multi-channel amp. NAD C272 150w x 2 powers my Polk RT800i towers and the Adcom GFA-7605 125 x 5 powers the CS400i, FX1000 and RTi6 speakersl
    Why?
    If I just want to listen music or watch movies with 1 or 2 ch soundtrack I use only my NAD C272 and the Adcom GFA-7605 stays off. But anything more then 2-ch I use both amps. This way I'm more flexible. One of the main reasons I bought Stereo amp because I'm a 2-ch music listener and very serious about it plus NAD C272 is one of the sweetest soundingl amps available in the market. IMHO I believe that Stereo amps mainly designed for 2-ch music and performs very well because of there internal design and engineering compare to multi-channel amps whereas Multi-channels are primarily for HT but still work excellent for music as well. The best thing about separates beside better sound is that you have more flexibility, room for upgradebility than a receiver.
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • goingganzo
    goingganzo Posts: 2,793
    adcom here 7 channel amp love it it is supper. next amp is sunfire sig 7 400 wpc dual outs for mains it is real sweet.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    I use 4 of the 5 ch's in Sunfire #1 to bi-amp my HT mains. No complaints here when I dial back to only 2 ch's. A quality HT amp can swing both ways.
    That said, I also have asorted 2 ch's for 2 ch...
    More later,
    Tour...
    Vox Copuli
  • nemos2
    nemos2 Posts: 111
    edited October 2004
    I use a outlaw 5 channel for both 2 channel and HT,
    Will have to agree with tour here.....a good ht amp should be able to swing both ways...
    that being said, I have never messed with a dedicated 2 channel system.....or tubes for that fact.
    Polk LSi 15 Fronts
    Polk LSi C center
    Polk LSiFX Surrounds
    Outlaw Audio 990 Pre/Pro
    Outlaw Audio 755 amp
    Paradigm PDR-12 Sub
    Outlaw Audio Cables
    BetterCables Cables
  • McLoki
    McLoki Posts: 5,231
    edited October 2004
    I currently have a 6 channel amp. (only 4 channels are currently working)
    I wanted something that could drive any speaker I choose to try and run as my HT expands. At the time I had LSi15s running and due to space and location contraints found the 7's with a sub run and look better than the 15's for HT. (When I get a larger room, will run SDA 1c's in the front (already own) and 7's in the rear.)
    I also am married with children and wanted something easy to run. (imagine the phone call - no sound from the center channel, look for lights from the 3rd amp up from the bottom on the second shelf.......)
    For my needs, this is a great setup so far. (but really need a better sub - hey, I already have the amp for it..... :)
    Michael
  • del44
    del44 Posts: 686
    edited October 2004
    Two amps here. 5 channel amp runs the center and surrounds. 2 channel amp runs mains in stereo and ht configuration.
  • jmierzur
    jmierzur Posts: 489
    edited October 2004
    Ditto.
  • astorpiazzola
    astorpiazzola Posts: 13
    edited October 2004
    i'm using the processor on the avr8000 with 7 channel stereo for music and thx dd ex for films(dual dsp).the avr8000 amp section is bi-amping the fronts and center.and the avr525 is bi-amping the surround, and amping the surr back and the center.
    avr525, avr8000, two pa2000
    four RTI10
    csi5
    six s36II jbl
    two m80 axiom
    two dvc punch3 rockfordfosgate
    AnD a PrOuD OwNeR Of 7 M200 OuTlaW MoNoBlOcKs
  • jmasterj
    jmasterj Posts: 327
    edited October 2004
    Hi Willow,
    I'm using a two channel Carver TFM-35x 250X2 for my main speakers in a HT set-up, with my receiver powering the center, and surround speakers. The carver is 2 1/2 times the power of my receiver. It's cleaner it opened up the front two speakers, and gives them much more detail than the receiver did. I listen to more music than movies, and really enjoy the sound from the power amp.
    JmasterJ Polk to the Death
  • George Grand
    George Grand Posts: 12,256
    edited October 2004
    I use two channel amps for my two channel rig, and my home theater rig. Why? Cause that's what I want to do.
    George Grand (of the Jersey Grands)
  • Willow
    edited October 2004
    Gee thanks George next time don't be so detailed..:cool:
  • Tour2ma
    edited October 2004
    That's NOT the road to a great, vintage receiver deal...
    More later,
    Tour...
    Vox Copuli
