Wall Brackets
Against my better judgement I purchased another pair of 703's. I want to use these as replacements for my Lsi 7's that I use as my rear surround speakers in my HT set-up. The problem is the 7's set nicely on my shelves but the 703's will not fit at all. I am being forced to mount the 703's on the walls. Is there any wall mounts that, 1-can support the weight of the 703's, 2-look half way decent, 3-can be mounted to wall studs. Any help would be greatly appreciated.
  • eclypse
    eclypse Posts: 595
    I've got a set that's like new that will work great. I've used the other pair for the past 4 years and still use them as I moved the 703s to front wides.
    Might wana try a seach and you may find the thread on here.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • shawn474
    shawn474 Posts: 3,052
    I have these mounts for a pair of LSi9's mounted on my wall. Not sure the dimensions of the 703's but see if these may work. I have them drilled into studs so they aren't going anywhere.
    http://www.amazon.com/B-Tech-BT77-Ultragrip-Speaker-Black/dp/B004DCAOHK
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • eclypse
    eclypse Posts: 595
    I have the same ones for my 703s but there a matt black. They work but the side rails are made for square speakers and the 703s are curvy. I had to use foam pads on the sides to make it fit tight.. but I still screwed the speaker on from the bottom with the supplied scews. Sucked to do but I couldn't take a chance of one falling out. I've had it happen with an older model polk square heavy speaker.. I belive it was the rti38. It survived the fall but dinged up one corner a little.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • sgtmick63
    sgtmick63 Posts: 166
    I will check these out. They look like they might do the job, Thanks
  • shawn474
    I have the LSi9's and they are a bit curved too. There is no way I would drill into the speakers. I actually just ziptied through the power port and around the mounting plate brace and it hasn't moved at all in over 5 years. I also have the same mounts for my LSiFX's, but they have to clamp front to back instead of the sides.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • eclypse
    eclypse Posts: 595
    shawn474 wrote: »
    That's smart.. though no such luck for the rti38. Right where the speaker fell is where my 2 year old plays with his train set on the train table. It actually smashed the side edge of the table. Thankfully it happend the same night I hung it while the kids where sleeping while I was wiring the speaker up to the amp.
    When I swapped them out for the 703s I tried the sticky foam tape suggested on the side clamps and notice it was slipping out of the grip a few hours later. It's was either screws or nothing. Figured no one would ever see the holes since it's a bookself speaker. Either on a shelf,stand or wall mount the holes would be covered and did not drill threw.
    Good idea though with the zip tie. If I would of thought of that I'd go with thick metal wire with a tie clamp.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • gp4jesus
    gp4jesus Posts: 2,019
    Cotytech Side Clamping Bookshelf Speaker Wall Mount SP-OS06
    Go to Speakers page. Look for my RTi A3 wall mount thread. Hope you like the pics.
    Tony
    *all connected w/Premiere ICs
