Wall Brackets
sgtmick63
Against my better judgement I purchased another pair of 703's. I want to use these as replacements for my Lsi 7's that I use as my rear surround speakers in my HT set-up. The problem is the 7's set nicely on my shelves but the 703's will not fit at all. I am being forced to mount the 703's on the walls. Is there any wall mounts that, 1-can support the weight of the 703's, 2-look half way decent, 3-can be mounted to wall studs. Any help would be greatly appreciated.
I've got a set that's like new that will work great. I've used the other pair for the past 4 years and still use them as I moved the 703s to front wides.
Might wana try a seach and you may find the thread on here.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
I have these mounts for a pair of LSi9's mounted on my wall. Not sure the dimensions of the 703's but see if these may work. I have them drilled into studs so they aren't going anywhere.
http://www.amazon.com/B-Tech-BT77-Ultragrip-Speaker-Black/dp/B004DCAOHKShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I have the same ones for my 703s but there a matt black. They work but the side rails are made for square speakers and the 703s are curvy. I had to use foam pads on the sides to make it fit tight.. but I still screwed the speaker on from the bottom with the supplied scews. Sucked to do but I couldn't take a chance of one falling out. I've had it happen with an older model polk square heavy speaker.. I belive it was the rti38. It survived the fall but dinged up one corner a little.
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
I will check these out. They look like they might do the job, Thanks
I have the LSi9's and they are a bit curved too. There is no way I would drill into the speakers. I actually just ziptied through the power port and around the mounting plate brace and it hasn't moved at all in over 5 years. I also have the same mounts for my LSiFX's, but they have to clamp front to back instead of the sides.Shawn
Front: Polk LsiM703
Rear: LSI fx
That's smart.. though no such luck for the rti38. Right where the speaker fell is where my 2 year old plays with his train set on the train table. It actually smashed the side edge of the table. Thankfully it happend the same night I hung it while the kids where sleeping while I was wiring the speaker up to the amp.
When I swapped them out for the 703s I tried the sticky foam tape suggested on the side clamps and notice it was slipping out of the grip a few hours later. It's was either screws or nothing. Figured no one would ever see the holes since it's a bookself speaker. Either on a shelf,stand or wall mount the holes would be covered and did not drill threw.
Good idea though with the zip tie. If I would of thought of that I'd go with thick metal wire with a tie clamp.
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Cotytech Side Clamping Bookshelf Speaker Wall Mount SP-OS06
Go to Speakers page. Look for my RTi A3 wall mount thread. Hope you like the pics.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
