RTi A5 placement
luhnk
luhnk Posts: 34
I have a 7.1 setup with a5's as my surrounds, 2 are beside me, the other 2 are about 10 feet behind my couch, is this too far away, what mounts can I use to bring them closer hanging from the ceiling? my living room is rectangular, I appreciate any help
CSi A6
RTi A5 x2
PSW125
RTi A1 x4
Onkyo TX-NR646
Sony PS4
Sony BDP-S5500
Monster HDP 2500
Panasonic 60st50
    F1nut Posts: 51,893
    I believe you meant RTi A1, yes?
    Your calibration program will adjust for the distance by boosting the volume and adjust the timing. If they aren't loud enough, you can manually adjust the volume, but keep in mind it's basically ambient sound fed to those speakers anyway. They are not supposed to stand out.
  • If you don't have a calibration program, it's just a matter of trial and error. Some people like each speaker to have the same volume and others, like me, favor the front three speakers to be a bit louder and the backs/ surrounds a little lower in volume. Adjust them to the sound that YOU like the best not what some written guide suggests.
    Ultimately, you are the best expert for your sound in your room.
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • luhnk
    luhnk Posts: 34
    edited April 2016
    so the distance isn't a problem, that was my concern, thanks you guys
    and crap, a1's, yes sorry
    CSi A6
    RTi A5 x2
    PSW125
    RTi A1 x4
    Onkyo TX-NR646
    Sony PS4
    Sony BDP-S5500
    Monster HDP 2500
    Panasonic 60st50
