Trigger cord/wire info needed
boston1450
in Electronics
Is there a site i can see & maybe purchase a decent trigger wire/cord for my Yamaha rvx-2600 trigger out to a Parasound amplifier ? I have this wire/cord (found in my cord bucket) & not sure its good enough. Thanks in advance.
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
Try it to see if they fit. Most likely sizes to work are 3.5 mm or 2.5mm or a cord with a combo of both. I believe the Parasound amp is 2.5 mm, I know my Halo A23 is and my P5 is 3.5mm.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Im afraid i will see smoke come bellowing out LOL... I will give it a try asap. ThanksRandy-Maine
by David WMG
it is only a 12v trigger won't smoke anything. That looks like 3.5mm pins both ends. Or, just use the on/off switches......lol.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
I use cheapie auxiliary cables (head phone jack on both ends). Haven't had a problem yet.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Thanks guys i will give it a tryRandy-Maine
by David WMG
yep when I could take advantage of that setup I used a very cheap rca mini to rca mini. No problems...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Nope. Didnt work. Fit in the Yammy but the Parasound is much smaller pinRandy-Maine
by David WMG
The Parasound as I thought is 2.5mm. You can get a combo.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Where do i get those. Can i get it on the bay ? If you happen to see a site/ad could you post it. I was gonna order one BUT was afraid id end up buying the wrong one.... So does that mean the Yamaha is 3.5 & Psd is 2.5 ? I couldnt find the size listed in the Yamaha & the cord fits perfect. The Psd is very small & manual states 2.5.. I wasnt sure the specs of the cable i haveRandy-Maine
by David WMG
I'd check monoprice ...
^^^^ i will try googling that. Ive never laid eyes on their site. ThanksRandy-Maine
by David WMG
Got this one coming. It helps knowing the sizes
. Thanks all. http://m.ebay.com/itm/2-5mm-to-3-5mm-Male-Headphones-Headset-Jack-Stereo-Speaker-Audio-Adapter-Cable-/311423593168?txnId=668977253021 Randy-Maine
by David WMG
Randy, if I remember correctly, it's a mono cable we use for triggers? Looks like Mike's got it working with a stereo cable. I didn't know you could do this. I think I remember back when I was looking for them, from feedback on the board, I went with the mono ones from Monoprice, just like Ken recommends.
I didn't know you could get a combo cable. Pretty neat. I'm also in this situation for a preamp/amp combo, and skirted it for now by using the triggered outlets on the power management center I'm using. Just another option if whatever you're using offers that, as well.
As I'm writing this, I went looking for these on Monoprice to send you a link and couldn't find them; weird, thought for sure that's where I got them, but then went to my cable stash tub, and it looks like I actually got them from MCM Electronics.
Even though you've got it sorted, I'll throw this info up well for sources for mono DC trigger cables in case anyone else needs anything like this.
This is the model/part number I used, the 24-810.
This is a 3.5mm mono cable - http://www.mcmelectronics.com/product/24-810
Here's a link to a search on MCM for 3.5mm to 2.5mm mono adapters - http://bit.ly/1MXitbX
Could go the other way with it and get a 2.5mm mono cable, and use a 2.5mm to 3.5mm adapter plug - http://bit.ly/1MXiUDd
I think your 3.5mm to 2.5mm cable is probably the better option, since there might not be much clearance back behind equipment to add an adapter?Post edited by msg onI disabled signatures.
