Trigger cord/wire info needed
Is there a site i can see & maybe purchase a decent trigger wire/cord for my Yamaha rvx-2600 trigger out to a Parasound amplifier ? I have this wire/cord (found in my cord bucket) & not sure its good enough. Thanks in advance. diok2vppidc2.jpeg
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • motorhead43026
    motorhead43026 Posts: 4,031
    Try it to see if they fit. Most likely sizes to work are 3.5 mm or 2.5mm or a cord with a combo of both. I believe the Parasound amp is 2.5 mm, I know my Halo A23 is and my P5 is 3.5mm.
    – Kevin Alfred Strom
  • boston1450
    boston1450 Posts: 7,758
    edited April 2016
    Im afraid i will see smoke come bellowing out LOL... I will give it a try asap. Thanks
    Randy-Maine
    by David WMG
  • motorhead43026
    edited April 2016
    it is only a 12v trigger won't smoke anything. That looks like 3.5mm pins both ends. Or, just use the on/off switches......lol.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I use cheapie auxiliary cables (head phone jack on both ends). Haven't had a problem yet.
    2 channel:
    Theater:
  • boston1450
    Thanks guys i will give it a try
    Randy-Maine
    by David WMG
  • rooftop59
    rooftop59 Posts: 8,120
    yep when I could take advantage of that setup I used a very cheap rca mini to rca mini. No problems...
    Game Room 5.1.4:
    Bedroom 2.1
  • boston1450
    Nope. Didnt work. Fit in the Yammy but the Parasound is much smaller pin
    Randy-Maine
    by David WMG
  • motorhead43026
    The Parasound as I thought is 2.5mm. You can get a combo.
  • boston1450
    Where do i get those. Can i get it on the bay ? If you happen to see a site/ad could you post it. I was gonna order one BUT was afraid id end up buying the wrong one.... So does that mean the Yamaha is 3.5 & Psd is 2.5 ? I couldnt find the size listed in the Yamaha & the cord fits perfect. The Psd is very small & manual states 2.5.. I wasnt sure the specs of the cable i have
    Randy-Maine
    by David WMG
  • ken brydson
    ken brydson Posts: 9,024
    I'd check monoprice ...
  • boston1450
    ^^^^ i will try googling that. Ive never laid eyes on their site. Thanks
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
    msg Posts: 10,472
    edited April 2016
    Randy, if I remember correctly, it's a mono cable we use for triggers? Looks like Mike's got it working with a stereo cable. I didn't know you could do this. I think I remember back when I was looking for them, from feedback on the board, I went with the mono ones from Monoprice, just like Ken recommends.
    I didn't know you could get a combo cable. Pretty neat. I'm also in this situation for a preamp/amp combo, and skirted it for now by using the triggered outlets on the power management center I'm using. Just another option if whatever you're using offers that, as well.
    As I'm writing this, I went looking for these on Monoprice to send you a link and couldn't find them; weird, thought for sure that's where I got them, but then went to my cable stash tub, and it looks like I actually got them from MCM Electronics.
    Even though you've got it sorted, I'll throw this info up well for sources for mono DC trigger cables in case anyone else needs anything like this.
    This is the model/part number I used, the 24-810.
    This is a 3.5mm mono cable - http://www.mcmelectronics.com/product/24-810
    Here's a link to a search on MCM for 3.5mm to 2.5mm mono adapters - http://bit.ly/1MXitbX
    Could go the other way with it and get a 2.5mm mono cable, and use a 2.5mm to 3.5mm adapter plug - http://bit.ly/1MXiUDd
    I think your 3.5mm to 2.5mm cable is probably the better option, since there might not be much clearance back behind equipment to add an adapter?
    Post edited by msg on
