Neutrik Mounting
Guys, long time no chat! I'll get to it..
I'm finally upgrading my SDA connection and have a couple of questions about mounting the Neutrik connectors.
The above picture shows small "tabs" on the female connector. I enlarged the holes on my binding posts cups to accommodate those tabs. I wanted to confirm whether or not that was the correct move (as opposed to enlarging them to NOT accommodate the small tabs) See picture below:
Lastly, I bought the 4 pole Neutrik connectors. I just wanted to confirm my thoughts on mounting the female connector. My thought is to drill the 4 holes necessary and mount them. I know - I can overcomplicate these things, but I did read a thread where someone said to just use two screws per connector?
Thanks guys!
Welcome!
    Here is a photo showing the "tabs"
    tabs.jpg 580.4K
    edited April 2016
    Which one is that as I don't recognize it. One thing for sure, it's not the recommended one, which only has 2 screw holes and no tabs. You have check the description carefully as not all of those are air tight.
    Oh yikes, that's not what I wanted to hear. Let me find the bag and get back to you.
    Somebody in the comment section asked if the male chassis connector (which I've been referring to as "female") was airtight or not and got a response saying that they are indeed airtight. I think I'm okay here?
    Ok, I looked at Neutrik's site and came to the conclusion you got the NLTMP-BAG, which is ok. The other more commonly recommended version is the NL4MP-UC.
    You might as well use all 4 screw holes, which are sized for 3M screws and be sure to seal up the backside of the hole it's in.
    Whew, sounds good! Thanks Jesse.
    Got this done tonight on my CRS+'s and I'm pretty sure I wired everything up right but I'd love if someone could confirm it for me.
    I took SCompRacer's advice on continuity and connected the pin's to -2 on the Neutrik connectors, and the blade's on -1.
    When I made the cables, I did the same. Positive (red) cable went to -2 and negative (black) went to -1.
    I connected the cables to this bad boy which GlennDog sold me (+'s are the bottom posts and -'s are the tops).
    It was too late to take a listen but I did fire the system up and it all seemed to work correctly at extremely low volume. Is there a quick and easy way to test or possibly even measure to see if I getting the right readings?
    Seems right to me. Just be sure to seal everything on the back of the binding post plate, hot glue works well.
    Lookin sexy! Sounds about like what I did on my second dread, except I used the screw retainer vs. solder-on SpeakOns. Did you get the rubber mounting seals for the face side of the Speak-On?
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    MrBuhl wrote: »
    Crap, no. I already sealed everything with hot glue :/
    These speakers are sounding GOOD.
  • It's ok they will look and work great, I did the same thing.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
    edited April 2016
    It will look better, and work better either way.. That black box looks familiar ;)
    Enjoy!!
Welcome!
Welcome!
