Neutrik Mounting
Guys, long time no chat! I'll get to it..
I'm finally upgrading my SDA connection and have a couple of questions about mounting the Neutrik connectors.
The above picture shows small "tabs" on the female connector. I enlarged the holes on my binding posts cups to accommodate those tabs. I wanted to confirm whether or not that was the correct move (as opposed to enlarging them to NOT accommodate the small tabs) See picture below:
Lastly, I bought the 4 pole Neutrik connectors. I just wanted to confirm my thoughts on mounting the female connector. My thought is to drill the 4 holes necessary and mount them. I know - I can overcomplicate these things, but I did read a thread where someone said to just use two screws per connector?
Thanks guys!
  • audiocr381ve
    audiocr381ve Posts: 2,588
    Here is a photo showing the "tabs"
    tabs.jpg 580.4K
    F1nut Posts: 52,011
    edited April 2016
    Which one is that as I don't recognize it. One thing for sure, it's not the recommended one, which only has 2 screw holes and no tabs. You have check the description carefully as not all of those are air tight.
  • audiocr381ve
    Oh yikes, that's not what I wanted to hear. Let me find the bag and get back to you.
  • audiocr381ve
    Somebody in the comment section asked if the male chassis connector (which I've been referring to as "female") was airtight or not and got a response saying that they are indeed airtight. I think I'm okay here?
    F1nut Posts: 52,011
    Ok, I looked at Neutrik's site and came to the conclusion you got the NLTMP-BAG, which is ok. The other more commonly recommended version is the NL4MP-UC.
    You might as well use all 4 screw holes, which are sized for 3M screws and be sure to seal up the backside of the hole it's in.
  • audiocr381ve
    Whew, sounds good! Thanks Jesse.
  • audiocr381ve
    Got this done tonight on my CRS+'s and I'm pretty sure I wired everything up right but I'd love if someone could confirm it for me.
    I took SCompRacer's advice on continuity and connected the pin's to -2 on the Neutrik connectors, and the blade's on -1.
    When I made the cables, I did the same. Positive (red) cable went to -2 and negative (black) went to -1.
    I connected the cables to this bad boy which GlennDog sold me (+'s are the bottom posts and -'s are the tops).
    It was too late to take a listen but I did fire the system up and it all seemed to work correctly at extremely low volume. Is there a quick and easy way to test or possibly even measure to see if I getting the right readings?
    F1nut Posts: 52,011
    Seems right to me. Just be sure to seal everything on the back of the binding post plate, hot glue works well.
  • MrBuhl
    MrBuhl Posts: 2,419
    Lookin sexy! Sounds about like what I did on my second dread, except I used the screw retainer vs. solder-on SpeakOns. Did you get the rubber mounting seals for the face side of the Speak-On?
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • audiocr381ve
    MrBuhl wrote: »
    Crap, no. I already sealed everything with hot glue :/
    These speakers are sounding GOOD.
  • It's ok they will look and work great, I did the same thing.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
    Toolfan66 Posts: 18,189
    edited April 2016
    It will look better, and work better either way.. That black box looks familiar ;)
    Enjoy!!
