wondering if my sda srs2.3 speakers are worth upgrading
Jessefaulcon
Just bought a pair of polk audio sda srs 2.3 speakers for 1000 dollars . they sound pretty good , but would like more definition and clarity .I was told a cross -over upgrade and a tweeter upgrade would help. seems its going to cost another 600 dollars . wondering if its worth it
Best Answers
Do you see yourself keeping these speakers for a very long time or are you kind of iffy about them and already ready to listen to others?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Jessefaulcon wrote: »Im new to the forum . feeling my way as i go . Love polk audio sound ! i have owned monitor 10 , sda 2b , and now sda srs 2.3 . read some things that implied 2.3 speakers may not be as nice as 2.3tl . is that true .? can I upgrade srs 2.3 to srs 2.3tl ?
While not impossible, it would involve changing everything and I mean everything.
The original crossover parts were not that great to start with and have now passed their lifespan, so upgrading the caps and resistors is a must do as is replacing the SL2000 tweeters with the RD0194-1. If you haven't already, adding high quality spikes will help tighten the bass and clean up the mid-range.Political Correctness'.........defined
Answers
Id like to achive good clean sound and keep them along time
Upgrades are worth it if you intend to keep. May be what you are driving them with is inadequate. These should sound dammed good bone stock.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
using adcom gfa 555 . They do sound very good ! I think they could sound better in keeping the mid-range sounds separate as the dynamic range increases . sometimes it gets muddy.
What are you using for a pre?Patriotism is the last refuge of a scoundrel…….Samuel Johnson
Changing to rdo194-1 tweeters will help everything balance out not just improve the top end.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
positioning is also critical. with upgrades done and proper placement, you will need to spend north of 8k to get what those will give you.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Agree to all the above! Worth it? Absolutely
