Nova Phonomena Phono Preamp MM and MC
ecod123
Versatile and well regarded phono preamp. Lots of positive reviews. This unit is in good condition. Lots of loading options via convenient dip switches for MM & MC (30 Ohms to 100K Ohms). Gain settings ranging from 40dB to 60dB, so also suitable for LOMC cartridges. Capacitive loading options of 200pF and 300pF. Ability to operate battery or AC power. Now that's a versatile phono preamp!
Power wall wart, manual and original factory box.
Forum price: $450 plus shipping from 91775. USPS Money Order or Paypal (add 3% for fees)
What are you replacing it with?
JC approves....he told me so. (F-1 nut) -
Hi George! I went with a tube phono, Manley Chinook. That's lovely 7308 sound.
May I ask how you like this? I'm considering picking one up locally. But is the version 2.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Mickey,
Not sure about the difference between the two versions but I would guess they share at least some similarities.
For my Nova, I love the versatility of the settings available, allowing me to dial in my many carts. In my system, It has superb details delineation, very neutral but not lean, and across the board realism. Instruments just sounded so realistic. There is texture to the voices.
Battery option has a quieter background but the AC option has a little more heft.
You should check out the many reviews, as they probably explain it better than me. -
IIRC it is a dual mono designJC approves....he told me so. (F-1 nut)
Yes, it is. Probably one of the key aspects of the design that make it performs so well at this price point.
George, what are you running for phono preamp now? -
Cinemag SUT and a Scomp built Hagerman Cornet II via way of CarlJC approves....he told me so. (F-1 nut)
I had a phenomena I I and it was very sweet. The I I had a Walwart ps instead of a batteryMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Still available?
