AR pro series II
Willow
any comments on these IC's are they much better than regular pro series ?
the reason I ask is there is a shop near me which is selling these off at unseen prices.... I bought an Svideo pro series II for 8.99$cad
Post edited by Willow on
I have a few and like them.. thicker cables, gold connections.. locking ends... yeah i think at that price buy them all.. nice cable.. a bit better then entry AR.. i had a source at the flea market where i was buying open packs of AR'S for like 3-4 bucks a pop...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I almost fell on my A$$ when I bought regular AR svid and optical for 1299cad when at box stores they want 19.99 for svid and 2999 for optical
their cable splitters a box store 2999....there 699
speaker pins for the ends...box store 24.99 them...2.99 for 4 -
wow great prices... they have banana plugs and stuff? i would grab up what ya need if you dont need ultra high end stuff. these will work great, IMOMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
is it worth replacing my reg AR cables with the pro II..and trust me I'm going this weekend to buy tons...even component (I can't use it yet but in the future I will)
no naner plugs just pins....but Ill keep my eyes open for sure
Can I use any type to replace my sub cable either audio analogue or a dig coax which would be better ??
The biggest problem with most interconnects, is the connector itself. Gold, sure, gold plated brass - and we all know how 'conductive' brass is.
If you have a good pair to begin with, twisted pair or coax, with decent shielding, I'd look into some WBT or Vampire Wire connectors, and re-terminate them.
That will undoubtedly be your best bang for buck option, and produce the MUCH better results, than simply 'rolling cables'.
Not speaking of anyone here directly, but it has always amused me how the brass jumpers on speakers get ditched - but everyone still uses brass connectors between all their gear.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
