AR pro series II
Willow
Willow Posts: 11,232
any comments on these IC's are they much better than regular pro series ?
the reason I ask is there is a shop near me which is selling these off at unseen prices.... I bought an Svideo pro series II for 8.99$cad
Post edited by Willow on
  • faster100
    faster100 Posts: 6,124
    edited September 2004
    I have a few and like them.. thicker cables, gold connections.. locking ends... yeah i think at that price buy them all.. nice cable.. a bit better then entry AR.. i had a source at the flea market where i was buying open packs of AR'S for like 3-4 bucks a pop...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Willow
    I almost fell on my A$$ when I bought regular AR svid and optical for 1299cad when at box stores they want 19.99 for svid and 2999 for optical
    their cable splitters a box store 2999....there 699
    speaker pins for the ends...box store 24.99 them...2.99 for 4
  • faster100
    wow great prices... they have banana plugs and stuff? i would grab up what ya need if you dont need ultra high end stuff. these will work great, IMO
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Willow
    is it worth replacing my reg AR cables with the pro II..and trust me I'm going this weekend to buy tons...even component (I can't use it yet but in the future I will)
    no naner plugs just pins....but Ill keep my eyes open for sure
    Can I use any type to replace my sub cable either audio analogue or a dig coax which would be better ??
  • RuSsMaN
    RuSsMaN Posts: 17,986
    The biggest problem with most interconnects, is the connector itself. Gold, sure, gold plated brass - and we all know how 'conductive' brass is.
    If you have a good pair to begin with, twisted pair or coax, with decent shielding, I'd look into some WBT or Vampire Wire connectors, and re-terminate them.
    That will undoubtedly be your best bang for buck option, and produce the MUCH better results, than simply 'rolling cables'.
    Not speaking of anyone here directly, but it has always amused me how the brass jumpers on speakers get ditched - but everyone still uses brass connectors between all their gear.
    Cheers,
    Russ
