Cambridge Audio Sonata
boston1450
boston1450 Posts: 7,758
edited March 2016 in 2 Channel Audio
AR-30. Just wondering if anyone here has/had one & what they thought about them ? It comes with iphone dock & remote & all accs. I got a old iphone & thought id learn how to put music on
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
    EndersShadow Posts: 17,741
    Well... I loved my DacMagic... I LOVE LOVE LOVE my Topaz SR20, so I'm sure that little guy would be nice...
    As long as the dock uses the same connection as your iphone (probably the larger 30 pin) you should be fine I would think... Otherwise older iPod Touch's are going for cheap I bet on eBay since they are outdated, but would work for just this purpose fine.
  • boston1450
    edited March 2016
    My daughter said its ipod touch & she does all that funky stuff with the ipod & old iphone 3 i think it is i had. That CAudio came with a station & manuals. I hooked it up to Klipsch kg3's & it sounds pretty good but the speakers are a tad big for the desk. So i may get smaller set
    Randy-Maine
    by David WMG
