Nad 2200 vs Parsound HCA-800II vs Hafler DH120 in bridged mode....?
Want to bridge one of these and sell the other two. So, thoughts...?? Won't be used in a critical listening arrangement but still want the "best" sound of these three....
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • honestaquarian
    honestaquarian Posts: 3,258
    Bridging an amp requires two for stereo.
    What will you be using it for?
    Do you have a second one for the other channel?
  • starkiller
    starkiller Posts: 2,723
    edited March 2016
    Yep, have one of each of the above....garage or bdrm system....
  • honestaquarian
    Okay
    Just to make sure I understand what you are saying.
    You only have one of each of those amps?
  • starkiller
    yep, so I want to decide one to keep and get another one of the same model to bridge...
  • honestaquarian
    The NAD is the more powerfull of the lot when bridged.
    I can't find any information on the parasound though.
  • starkiller
    WPC isn't everything though, sound quality also counts too me...
  • skrol
    skrol Posts: 3,460
    edited March 2016
    Here is the OM with specs for the HCA-800ii. I have one of these that I may consider selling. The only thing is that I recap'd it with nice Nichicon caps, Clarity Caps and has other tweaks and may not match your amp any more.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • starkiller
    stan
    do you mean match in wpc or sound quality or both?
  • skrol
    skrol Posts: 3,460
    Sound quality. I bought this amp along with a C/PT600 pre-amp from a fellow Polkie as an intro to separates. They both needed some TLC.
    I notice a nice improvement replacing the old, lower grade caps. About 1/3 of the caps in the amp and pre-amp had gone out of spec. I did not change the large power supply caps as they are still good and a pain to replace.
    This was not a John Curl design and they did some odd things, like placing the headphone jack and speaker selector switches near the noisy toroidal transformer. I added some shielding. I also increased the internal speaker wire gauge and tried to re-run low level signal wires away from noise sources. I also disconnected the phono plug inputs, leaving only the RCA as they were another possible source for noise. All this resulted in a lower noise floor. Combined with the pre-amp, that also got the treatments, the background became nice and dark, the sound stage more transparent and dimensional.
    I'd still be using it today but I had an opportunity to snag an HCA-1000A that also needed some TLC. I did a full re-cap and got some pointers from the man himself (Mr. Curl).
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • starkiller
    hmm, if you were to sell it what would you ask for it? love the Curl stuff...
  • starkiller
    Any other thoughts??
    starkiller wrote: »
    If that's the case, I'd forget about bridging any of them. What are you going to be driving with these anyway ?
  • starkiller
    either vienna acoustics bach or allison 6s or sonab od12s...
  • starkiller
    k', guess that's it eh?
    Honestly, I'd sell all 3 and buy one good/better amp and forget about bridging anything.
  • Polkie2009
    Polkie2009 Posts: 3,834
    Add me to the sell all 3 list. :) There's always nice used gear popping up in the for sale section here you might like.
