SDA Interconnect
xjghost
I have some extra banana plugs and was going to make an interconnect and ditch the RCA cable with broken off tabs. I was going to search but I couldn't figure out how on the new software. Anywho, question is what gage wire? I have some 16 gage speaker wire laying around is that decent or should I use something else??
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
What gauge ya usin for the normal speaker wire?
I think it's 12. I don't remember actually. It's bigger then 16!HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Additional projects: RTA 12c's -
What is the OEM wire gauge for the SDA cable? I'm thinking 16 or 18 gauge. Maybe it varies with year or with speaker model.
The original on my SDA1C's was 16 gauge, and 20' long. I used 12 gauge when I replaced it, because that's what I had on hand.
I looked at the banana plug and the back of the speaker.... that aint going to work.... Back to the drawing board....HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Just replace the SDA connector with a standard binding post.
For the 3.1TL's, replace the pin/blade socket with a Neutrik socket and use Neutrik connectors for your new cable, which should be the same type/brand cable you use for your speakers, which only makes sense if you think about it.Political Correctness'.........defined
President of Club Polk -
I listened to F1nut and westmassguy and used the Neutrik connectors. Cost effective and great connectors.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Hey guys new to the forum! This modification of changing to a binding post can be done with Sda CRS+ and SDA 2 as well?
It can be done to any SDA, you just need to know how to wire it all up. There are schematics posted here for most of them.
Edit: better than a binding post are the SpeakOn connectors.Political Correctness'.........defined
This thread looks like a few months old but if another opinion is needed for the cable conversion here's mine. I tried doing it myself and butchered the terminal cup and was not getting the desired effect. I gathered all the parts,sent them out to Dave and he gave me new cups, binders, w/ the Neutrik/Speak-On connectors. Now ALL speakers are reacting as they should w/ the added fact my rack changed I'm now hearing things I should of years ago. Price we don't talk about here but to say it was worth it would be a gross understatement. I don't think a single banana plug is notsuch a terrible idea but the locking action of the Neutrik is better. I also used 12gu spkr cable, the same I ran to the 2Bs. I think all the parts w/o the cable were less than the shipping from PE.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
One of the reasons we suggest the speakon connection is it keeps someone else from sticking a speaker cable in the wrong binding post and letting the magic smoke out.....
Thanks guys and sorry for the thread revival didn't realize it.
Glad you did. Life got in the way and I never ordered the parts. They came in this week! I have too damn many projects.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
