Is there such thing?
edited September 2004 in Electronics
My dad wants to put a 110V system on our boat, and as boats vibrate and bang once in a while, someone suggested that instead of using CD's for music, use something in like an MP3 format. This way our music will be on a chip instead of a CD that might get damaged.
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
Welcome!
    I am assuming your boat is a 12 volt system, and you dont want to use a 12 volt MP3 head unit and 12 volt amp right?
    There are power inverters like this that step voltage up to 120 VAC, you pick how many watts you need. The more watts, the more money.
    Graham
    Right now it is 12 volt but we want to go with a 110 volt system. We have all the power we need since it has a 50 amp service along with a 12.5 Kw diesel generator.
    Main System:
    Second System:
    Ipod.
    Is there something that is not in a portable format like the ipod?
    Main System:
    Second System:
    Velcro? Why wouldn't you want it portable, you'd want to load music on it for the trip, no?
    Yeah I guess we would want to be able to load music on to it. I don't really know what the best solution is, I am only trying to pick everyones brain and see what they think is the best idea. We have the power, and the space which will allow for multiple solutions, we just want the best one in the long run.
    Thanks for the suggestion. Keep em' coming.
    Gerry
    Main System:
    Second System:
    Sounds more like a ship than a boat... How many feet is it?
    More later,
    Tour...
    Vox Copuli
    The boat is a 1992 46' Silverton Motor Yacht
    How do post a picture?
    Main System:
    Second System:
    do you listen to tunes while cruising ??
    if not do like we did..hook up a car cd player. we have 2 batteries on the boat one for cabin use and one for the engine...
    Willow,
    Yeah we listen to tunes while cruising and we already have a 12V system but want to go to a 110V system.
    Main System:
    Second System:
    Yup.... it's a ship.
    If on your computer, when you "Post Reply" use the Browse feature for attachments below the text box. Pic must be reduced in size (< 100 kb I think). And do not preview your post or the pic will not appear...
    More later,
    Tour...
    Vox Copuli
    Willow,
    where is your boat ours is at treasure Island near Kingston it's a 32ft sail boat
    Willow,
    Here is a picture from last fall. She is sitting behind our house on the boat life my dad and I built and designed. Thanks Tour2ma!
    Gerry
    Main System:
    Second System:
    I will try again.
    Main System:
    Second System:
    Here we go! wait... nope
    Main System:
    Second System:
    all fixed
    Main System:
    Second System:
    ha
    Main System:
    Second System:
    ok
    Main System:
    Second System:
    you want like regular stereo equipment for your house on your boat? i'm not sure if thats what you want because i don't know the voltage of equipment. if thats what you are looking for there are companies that make hard drives that hook into your home stereo. they are called hard drive music servers i think. if thats what you are lookinf for marantz makes something like that, http://www.hedmag.com/Product-Reviews/Audio-Electronics/Service-for-Four.asp
    i'm sure there are other companies that make them also. if this isn't the type of thing you are looking for then id just stick with a real nice car stereo. the ipod thing doesn't sound like it would work so well. portable devices don't sound so nice with bigger speakers. the signal they output must not be very strong or something because even with the volume all the way up they are still pretty quiet.
    good luck with ur search, hope i helped. btw really nice boat.
    Airplay,
    That sounds like a great idea, should be just what we need. As for power I'm not worried, we've got the same power as a normal house. But just to be safe we will probably buy some kind of power protector or something, I don't know.
    Main System:
    Second System:
    Airplay,
    I just looked a little closer at the link you posted. That unit there is a little, just a little to expensive for what we need. But I think we are headed in the right derection. Whats everyone else think.
    BTW, what do you think of our boat lift?
    Main System:
    Second System:
    I'm not really sure of the prices on these units but i would imagine the onkyo would be less then the marantz.
    http://www.epinions.com/Onkyo_20GB_Hard_Disk_Music_Library_MBS1__CD_Recorder_MBS1/linkin_id_~3035301/display_~reviews
    obviously not as nice of a unit but it does the same thing. i think rotel makes a unit like these but i bet its expensive.
    Well we just finished the system on our boat until next spring. So far we have the following installed, don't get mad at me because it is not polk, we had to go with these because of size and installation and all that fun stuff.
    Denon AVR-2805
    Paradigm Stylus 350
    Paradigm CS-150
    Paradigm AMS-100R
    Home Theater Master Remote
    Panasonic DVD player
    Next spring we will probably add another pair of Paradigm AMS-100R's and put in a Yamaha CDR-1300, I think that is the model number.
    She is sounding pretty good, especially without a subwoofer.
    Jerry
    Main System:
    Second System:
    Very nice boat! or in this case what a SHIP!!!:D
    Good for you.
    HBomb
    ***WAREMTAE***
Welcome!
Welcome!
