Cleaning K&N air filter?
Pick up a K&N filter cleaning kit, and it will tell you that you want to run water through the filter from the inside to the outside so the dirt that is in the filter gets forced back out by the flowing water, rather that driving it further into the filter by running water over the outside.
So by that explanation of how to get it clean, you can see why dropping the filter in a sink of soap and water isnt the best way to do it, it would get some dirt out, but also push some dirt further into the filter.
I've used K&N filters on all my motorcycles and cars since I was a kid and that's over 30 years now.
There's nothing better than a K&N filter.
Here's a good tip....
If you want more miles out of the filter without cleaning it, just slide the foot section of an old pantyhose over it to act as a pre-filter.
It will stop most of the larger dust and and road debris as well as insects from clogging up the filter too fast.
All you need to do is pull it off and shake it out or replace it a few times a year.
A pre-filter is also highly recommended for dusty off-road environments. -
Power washer on full blast, with a small child behind it.
I run K&N in all my vehicles, even the work truck. Have I noticed increased gas mileage? No but I haven't paid much attention in 20+ years either. My foot would ruin any benefit anyways but I like to hear the "breathy" sound when I stomp on the pedal.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I don't know if this would work or not but someone mentioned using the K&N recharge kit. There is also a filter cleaning tool that I've used on my truck & shop-vac called Power Pic Pro. It fits on a garden hose or like I do, I just hook it up to my kitchen sink with an adapter and use hot water to clean it..... There is another tool called Filter Flosser too. Hope this helpsSerendipity wrote: »How do you clean the air filter properly? I've heard stories about doing this incorrectly and causing damage to some part (MAF??)
Jstas...and others, maybe you could help me figure this out
Thanks! -
Here's my take on K&N filters.
K&N was designed for race cars and to let more air in to match the high flow performance exhaust systems.
More air = more dirt, which isn't really a problem if you're going to tear down your engine after a few races, but I wouldn't want to subject my motor to long term use of one.
I keep my bikes stock and trust that Honda's research & development knew what they were doing when they designed how much air flow was needed to make it run right. -
I have used K&N type filters for aftermarket intakes on many of my cars for a total of 3 decades now............the more air=more dirt (when talking about automobiles) is not an issue at ALL, ever. Unless you don't clean and "charge" the K & N type filter at proper intervals, then perhaps this might be a minor issue.
For motocrossing or other extreme sports, dune buggy's, rally racing perhaps there is a small slice of evidence to your "dirt" claim.
In fact if you want to do some research, I bet the K&N types actually trap more dirt and dust and pollen than a standard gauze, paper element filter.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Polkaguy58 wrote: »Here's my take on K&N filters.
You obviously don't understand how K&N air filters work. Not only do they increase the air flow, they stop more dirt from passing through at the same time.Political Correctness'.........defined
President of Club Polk -
Looking back through this old thread......a lot of members MIA :'(Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I've never had any issues with k and n filter...other than it being a tight fit around the air intake hose (it's not the drop in type). I have my old filter which I put in the intake while waiting for the k and n to dry...so I am never without an air filter in the car in case I need it.lsim705,lsim706c,lsif/x(4)+mc80(atmos)
rti6,csi5,fxi5 -
Does the k&n really improve fuel economy?
No
But it sounds awesome.
I don't know how I got this far back on the forum....
Somebody help me, I think I am lost.B&W CM9Classé Sigma -
Pretty simple really Spray it down with the cleaner then spray it with the hose let it dry. I use a regular air filter in its place while it's drying. Gas milage improvement probably not the ol Yota 4x4 gets 18mpg on a good day.Home Theater
Modern auto's will not benefit gas mileage wise from a K&N air filter. Sensors (MAF) will compensate for the additional airflow by enriching the fuel mixture. This avoids what is referred to as a lean misfire, which results in an increase in CO2 emissions. There will be those that argue that they get better mileage. So anything is possible, but this would be an exception, but not the norm. Another fact is the dirtier a K&N filter gets the more efficient it becomes @ filtering. Now there is a point of diminishing return as an extremely dirty filter will not be efficient. I actually only run K&N on my carbureted cars, and always the ones that I run @ the strip. I have jet and needle kits that I can make internal carb adjustments quickly due to air temps, humidity and so on. Therefore I want to have one common denominator a high flow air filter that does not get in the way, yet protects my investment just enough, and I say "just enough" because a real clean K&N air filter is not as efficient at filtering as paper or felt air filters. Not a problem as these cars see 2000 miles a year if that much.
K&N has done a marvelous job marketing over the years, but the bottom line is these are not necessary or even the best filter for your daily driver.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
All in your opinion, of course.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Deleted,not worth it H9.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
I'm not going to argue with you, just disagree with some of the things you posted as fact.
I've used K&N for close to 30 years, albeit on modified air intakes (only once as a drop in) and they have exceeded the stock setup. I've never heard "a dirty air filter is more efficient than a clean one". I'm all ears on that one, and I'd be interested in some solid proof. I have gotten better mileage and throttle response, but again, the intakes are not stock that are attached to the K&N filter.
Unfortunately, you can't buy a stock filter to fit on a modified intake.
Bottom line, is they work well for me, so I will always use one.
I have very little to no experience with K&N drop-ins to a stock intake system. So I am speaking strictly about aftermarket air intakes utilizing a K&N filter.
Here ya go.. Get a Volant CAI with a Power Core filter option. Go to 58 seconds on the video. No oiling, no cleaning and lasts 100K miles or 4 years. The sound when you mash down on the gas pedal is a plus too
https://www.youtube.com/watch?v=SyoSx3WfXZ8 Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
When I had a K&N, I would spray the cleaner and let it soak for a few min. Then I would place it over my utility wash tub faucet and let the water pour from the inside out slowly rotating it. Then I would repeat then place the open end over my HVAC floor duct and it was dry by morning.
After some research I tossed it in favor of higher filtration of my stock AC Delco filter. If I went with another type of filter like the K&N, I would get the Green FIlter. I don't like the K&N because of the reported fine dust that gets through, IMO, the little it gives over stock isn't enough to warrant using a filter that allows more fine dirt to get through. YMMV.
