system
golfinguy
golfinguy Posts: 3
edited September 2004 in Flea Market
Hello everyone....
I'm a newbie to home audio, but need info. Don't flame me if I sound ingnorant....
I have a guy who wants to build me the following:
yamaha rx-v2400
(2) Lsi15
LsiC
LsiW
(2) pair LC65i or maybe (2) pair RC85i
Mitsubishi 62725 DLP
Is that a good match? What questions do I ask the guy? He sounds knowledgeable.....but again I'm a newbie...
Post edited by golfinguy on
  • brettw22
    brettw22 Posts: 7,623
    Hello.....welcome to the forum....
    Few questions:
    Is that all stuff that you currently have or are going to be purchasing based on his suggestions?
    Have you ever listened to the speakers?
    Checked out the receiver?
    Looked at the TV?
  • danger boy
    danger boy Posts: 15,722
    you're talking a goodly amount of money there....
    you have ask yourself.
    1. how much will I be using this for home theater and how much for CD/music listening?
    2. budget - this is what determines what a lot of people do with.
    3. taste in sound - here again... the skys the limit in terms of how much you can spend to get the sound you want.
    finally... those Polk Audio speaker are the top of the line LSi speakers... they are not cheap.
    at first look... it appears the guy does have some knowledge of gear. but is this HIS dream system.. or yours?
    i would proceed with caution.
    PolkFest 2012, who's going>?
  • Frank Z
    Frank Z Posts: 5,860
    The system he's suggesting will sound fantastic. Any chance you can audition it before purchasing?
  • golfinguy
    golfinguy Posts: 3
    heard the speakers...seen the tv...haven't checked out the receiver with the speakers, but with others....
    it's within budget, but barely....i'm getting sidelong glances from my wife....just want to make sure that I don't end up the fool.
    thanks a mil for the advice, and I'll proceed with caution, DB, thanks.
  • Toxis
    Toxis Posts: 5,116
    Wrong forum first off... but that's ok.
    That is an awesome AWESOME tv for the money. I love the new Mits DLP's. Plus, the system is killer but I'd go with a different receiver personally. Like a Denon 3805 or something similar. What's the price he's shooting you for everything? It might be a good deal or a horrible deal, depending on how much he's marking stuff up on you.
  • brettw22
    I think the weakest link in the equipment you mentioned is the Yamaha, for two reasons....
    1) Not powerful enough to run the LSi's with the type of power they need. The LSi's, as 90% of the forum will indicate, need seperates to really come alive. I scanned Yamaha's site and they don't even list any 4ohm ratings for their stuff, so I don't know what power you're going to be getting them. Also, some have gotten away with running the LSi 9's and 7's off a receiver, but IMO the 15's are too much speaker alone, let alone with the C and inwalls in the mix.
    2) Many people feel that Yamaha receivers are pretty bright sounding, and that might be a source of concern. Before you go and drop the serious coin that you're going to on that setup, I'd make sure you get the speakers on the receiver you're looking at to see if you even like the sound. True, there is a break-in factor on the speakers, but you have to at least see what you're starting with at the receiver end.
  • PolknPepsi
    PolknPepsi Posts: 781
    I certainly believe you are getting some good thoughts suggestions and solid ideas from these guys...................
    Pat
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • TheReaper
    TheReaper Posts: 636
    I agree with brettw22. The yamaha rx-v2400 owners manual specifies a minimum speaker impedance of only 6 or 8 ohms. The LSi speakers are 4 ohms, the receiver is not designed to drive speakers of this low impedance (and may void the warrantee).
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • faster100
    faster100 Posts: 6,124
    Seems like a large first system, Not that a audio newbie can't have a nice system first thing... But alot of people start a bit smaller and work up.. I would also say the receiver is the weakest link.. and if your barely in budget then getting something to power all those Lsi's will put you over the top. maybe consider a smaller main speaker, a preamplifier and amp to power the Lsi's and maybe reduce how many surrounds you have to save some coin for the main gear.. Lsi's are different then alot of other speakers and polks and i would listen to them alot to make sure you like them, try the lsi9 for mains, the lsi7 with the lsiw would be a good match./.. and again save money and get you out of a receiver and into a pre/amp combo.. Yes and i would shop around and see if "his" price is the best price for ya... Good luck
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Dump the yammer, you will want to anyway after a while with what you are getting for the rest of the system, might suggest some seperates for pre/pro and amp. Outlaw would be an excellent place to begin. Also, Rotel, B&K, and Sunfire to name a few and if you want to spend the bucks.
    RT1
  • dorokusai
    dorokusai Posts: 25,640
    No offense intended to Yamaha fans, but ditch the Yamaha.
    The Outlaw combination is a powerful one, and none of your friends have it most likely. The Outlaw brand is becoming pretty solidified in the market. It has a very high "bang for the buck" rating.
    The Rotel/B&K/Sunfire brands are serious choices, and will spice up the wallet action, but the payoff is tremendous.
    Be different, don't follow the pack.
    www.outlawaudio.com
  • goingganzo
    goingganzo Posts: 2,793
    the lsi will over heat most all in ones unless you get a high end one and that will still ware donw the life of the unit. i will say get a used pre pro and a set of lsi9 and a good sub and you wull not see the differance.
  • golfinguy
    golfinguy Posts: 3
    wow...thanks a bunch for the info....will talk with him regarding the receiver. Finally I get some advice that doesn't have a pricetag associated with it. But I still love those speakers...may bust my budget just to have 'em. I've looked at the Denon 3805...again not with the speakers....not too much more money...is it that much better than the yamaha 2400?
  • brettw22
    Better, but what you're asking a receiver to do with those speakers is NOT going to be a good thing for the life of the receiver.
    In all honesty, if you're budget is strapped with the stuff you outlined in your initial post, I'd consider going with the RTi line. Those won't have any problems being run off of a receiver, and you will be in much better shape as for protecting your investment.....
  • HBombToo
    HBombToo Posts: 5,256
    www.outlawaudio.com
    Buy Outlaw right up front if you want to own LSi's. I have owned an Outlaw 770 over two years now and its been worth every pennie. The mono blocks are a good way to test the waters only on your fronts. Let your AVR handle the center and rears plus you'll have a good upgrade path.
    HBomb
    ***WAREMTAE***
  • lomic
    lomic Posts: 407
    My LSi7's have always had a seperate amp pushing them, but as of today I can attest that the LSi's are nothing without good power.
    I'm visiting my folks in Phoenix, and stopped by the Tweeter (Home Theater Showcase) in nearby Chandler. One room had a Denon 2200 hooked up to a B&K amp going to LSi25's... unfortunately the 6CH analog cables weren't hooked up so we had to go to the other room.
    Let's just say it should be a crime to drive LSi15's with a Sony AVR. I think the guy realized the problem when I asked him to turn it off after about 15 seconds of DSOTM SACD. Absolutely no bass coming out of them, and they were clipping at -25 from ref. Just hope he didn't damage the poor things. I wanted to grab them up and rush them out of the store like they were children in an abusive household :mad:
    Unfortunately that was the only reciever/amp close enough to the SACD player to hook up. What a shame, I really wanted to hear some SACD on LSi's before I plunk down $500 for a Denon universal player.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • HBombToo
    i have the 2900 and its outstanding
    ***WAREMTAE***
