pre-outs help
Willow
so preouts are an RCA plug but from the out where do the RCAs gte plugged into the second receiver or AMP ??
Post edited by Willow on
yes.. from the back of your receiver. you'll see PRE OUTS for Left, Right, Center, Sub, Right Surround and Left Surround, etc.
use an RCA interconnect from each one of those outs to the Input of an amp.. then hook up your speakers to the rear of the amp.
that's it.. you should do fine after that.
what kind of receiver do you have?
what kind of amp do you plan to use?PolkFest 2012, who's going>?
The left and right channel inputs on the amp. You can't hook up a receiver to a receiver.Political Correctness'.........defined
President of Club Polk -
thanks...not using any right now just trying to understand how it worked.
so you can't preout to another receiver...ahhh I see thats what I was trying to uderstand.. I have never seen the back of an amp so I didn't know how it was connected either.
Not unless the receiver has pre-amp inputs.Graham -
it's making sense now....I saw the back of an amp now but it only has hook-ups for what looks to be speaker cables. where do the pre-outs hook up to ??
Thanks I now see the inputs !!! sorry for the confusion
amps don't usually have many in's or out's.. they are pretty simple to use.PolkFest 2012, who's going>?
... or "tape in"...Originally posted by gatemplin
Not unless the receiver has pre-amp inputs.More later,
Tour...
Vox Copuli
So,
If your receiver doesn't have any preouts (except the sub) is there any way to hook up a amp to it?
"The only stupid question is the one not asked" right? kevinThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
No, not any that give the receiver control of the volume anyway. "Tape out" could be used, but it is a line level output, bypassing all controls.More later,
Tour...
Vox Copuli
