pre-outs help
Willow
Willow Posts: 11,233
so preouts are an RCA plug but from the out where do the RCAs gte plugged into the second receiver or AMP ??
Post edited by Willow on
  • danger boy
    danger boy Posts: 15,722
    edited September 2004
    yes.. from the back of your receiver. you'll see PRE OUTS for Left, Right, Center, Sub, Right Surround and Left Surround, etc.
    use an RCA interconnect from each one of those outs to the Input of an amp.. then hook up your speakers to the rear of the amp.
    that's it.. you should do fine after that.
    what kind of receiver do you have?
    what kind of amp do you plan to use?
    PolkFest 2012, who's going>?
    F1nut Posts: 51,787
    The left and right channel inputs on the amp. You can't hook up a receiver to a receiver.
  • Willow
    thanks...not using any right now just trying to understand how it worked.
  • Willow
    so you can't preout to another receiver...ahhh I see thats what I was trying to uderstand.. I have never seen the back of an amp so I didn't know how it was connected either.
  • gatemplin
    gatemplin Posts: 1,595
    Not unless the receiver has pre-amp inputs.
    Graham
  • Willow
    it's making sense now....I saw the back of an amp now but it only has hook-ups for what looks to be speaker cables. where do the pre-outs hook up to ??
  • hellotheworld
    hellotheworld Posts: 205
  • Willow
    Thanks I now see the inputs !!! sorry for the confusion
  • danger boy
    amps don't usually have many in's or out's.. they are pretty simple to use.
  • Tour2ma
    Tour2ma Posts: 10,177
    ... or "tape in"...
    More later,
    Tour...
    Vox Copuli
  • opus
    opus Posts: 1,252
    So,
    If your receiver doesn't have any preouts (except the sub) is there any way to hook up a amp to it?
    "The only stupid question is the one not asked" right? kevin
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • Tour2ma
    No, not any that give the receiver control of the volume anyway. "Tape out" could be used, but it is a line level output, bypassing all controls.
    More later,
    Tour...
    Vox Copuli
