cleaning out, good deals
nadams
Have some drivers, crossovers, and other bits that may be of interest to some of you. The list:
Pioneer TS-162 6 1/2" Full-range speakers
6 1/2" Dual-cone
Max 80w, RMS 20w; 4ohm
45-18,000Hs, 92dB/W (1m)
Water-resistant cone
Strontium magnet
shallow basket design
Paid $20 for these on a closeout a few years back, all I'm asking is shipping costs. Come with grills and packaged in the original box and packing material (box contains two speakers). Date on the packing label is 8-22-00
Optimus 3 1/2" Super Horn Tweeter (RS Cat # 40-1218)
*Description removed* RuSs has dibs
XTC 6x9" foam baffle
Brand new, accidently bought two pair when doing a system in a car. Crutchfield sells 'em for $9, give me $5 and they're yours.
RS 3-way passive crossover
Cat No- 40-1299A
800hz/5000hz, 800hz/7000hz, 1600hz/5000hz, 1600hz/7000hz
Cut off: 6dB/octave
100watts nominal power
Still in original boxes, but are used. Work fine. Slightly on the heavy side. I found the receipt that shows I paid $20/crossover in August 2000. I'd like to get $10 plus shipping for the pair. Hell, they're even still in the plastic bags and everything.
Profile California QX8 Powered subwoofer crossover
12dB/octave slope
High and Low level inputs
switchable crossover frequencies (70/90/120)
+-12dB Variable bass boost (45hz)
Variable input gain controls
gold plated terminals
I used this for about 2 months until I got a head unit with preamp outputs. Paid $20, asking for $5 plus shipping. Again, like new in it's original packaging.
"The Right Connections" RCA Ground Loop Isolator
A piece purchased from Parts Express. Didn't fix my problem. Still new in box, only installed to find out it didn't fix it, then threw it back in the box. $5 plus shipping
Anyone who wants pictures just post back. This is a bit of stuff to post all kinds of pictures just to find noone's interested. If you're interested in more than one item, they will obviously be shipped together, which = cheaper. Thanks for looking.
6 1/2" Dual-cone
Strontium magnet
Cat No- 40-1299A
Cut off: 6dB/octave
12dB/octave slope
Ludicrous gibs!
Set the rat shack super tweets to the side for me.
Cheers,
Hey, can I get pics of the Pioneers? Thanks.
Working on the pictures :-/
I have them, but the server I host them on is down right now. I'll try to get them up tomorrow ASAP.
Sorry,
nadamsLudicrous gibs! -
http://www.king-nerd.com/dood/pioneerspeaks.htm
There ya go.... in almost perfect cosmetic and sonic condition. A little dusty, is all :-)Ludicrous gibs! -
Just so you all know the "optimus" (radio-shack) brand is entirely produced by Pioneer... so it's as good as pioneer.___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
Hmm... that odd, I've never heard that before. When my local RS moved all their optimus stuff out, it was replaced by RCA components that looked EXACTLY the same. All the way down to the Linaeum tweeters on the small bookshelf speakers. I was going to assume that RCA bought out optimus, but I could be wrong.Ludicrous gibs!
