What is preferred speaker connection?
Gunther16
I've been debating the question of preference of connecting speakers via spade lugs and banana plugs. What does the community think?
Best Answers
Personal taste, and many times what's best fit for your gear
I have amps and speakers that are better suited each type2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I went to spade/spade but now with my setup changed I hate using spades with my Amplifiers...but that is just me...
but for speakers with their binding post up high in the air I like the idea of "Angled Banana plugs" but have not tried some yet.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Bananas are easier to install and uninstall. Spades are a stronger gas tight connector but not as easy to use. I use spades on the speaker end of cables and bananas on the amp end with space available to do the connecting a factor.Post edited by Emlyn on
whatev's.
I like bananananananas because they're easy -- and I am lazy.
In fact, when circumstances permit dual bananas (3/4" spacing), I like that even better... because I am really lazy.
Indeed, I went to Pomona dual bananas with my Monitor 7As when I was in college (late 1970s) -- I have been really lazy for a long time.
There's a school of thought (in all seriousness) that will hard-wire loudspeakers to amplfiers (i.e., permanent connections vs. easily changed ones) -- no compromise, you know?
Spade lugs, ring lugs or stripped/tinned bare wire...
It's all good.
Spades on speaker. Locking bananas on the amp.
Because I am The Pumpkinking
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I will take a swing at that. It is about the space to work in. Usually you have more room to fiddle around behind speakers than amps.
I am lazy too, bananas all around. -
Banana's all around for me. I had spades at one time but disliked the fact that they always seem to loosen up on me. To need a wrench to get tight enough or to switch to me seemed counter productive.
afterburnt wrote: »I will take a swing at that. It is about the space to work in. Usually you have more room to fiddle around behind speakers than amps.
That pretty much covers it. I like locking bananas on heavier gauge cables. You know the cables that seem to have a mind of their own.
So what I'm getting out of this is that there is no preference for either other than convenience. Maybe I should restate the question. Which is the best, making any audible difference, method of connecting the speaker wire to the speaker using 5way binding posts?
Very interesting responses. I'm particularly interested in the replied stating banana plugs on amp but spades on the speakers. Why? Why not the other way around?
My 703's are on stands. The speaker cable goes through a loop down to the bottom of the stand. Spades puts less of a bend on the cables as they go down.Anaheim Hills CA,
Gunther
It's really your call on that we do not have your ears. -
From an audibility view, it doesn't make a difference. If it did, then we would see speaker and cable manufacturers only provide us with one option for connection. But they offer everything from bare wire to spades, bananas, etc., for your consideration. For me, I tried all forms of connections on my amps and speakers and couldn't tell the difference.
I once calculated the contact area of MIT banana plugs and spades. The banana plugs have slighty more contact area. However, you'll never hear the difference.
My personal preference is banana plugs. Spades are just a PITA.Political Correctness'.........defined
President of Club Polk -
Amen, brother! -
Gunther16, I will say that the quality of the terminations and the material they are made from does have an affect on the sound.Political Correctness'.........defined
Dang, you beat me to it.
Yes, not all connectors are made equally, and that can affect the sound some. Bare wire is eventually going to oxidize and dull the sound so either bananas or spades is the preference.HT SYSTEM-
lsi 9's -
I like bare wire on the amp terminals, to me the most efficient and simple.
On speaker terminals, bare wire does fit the wholes, so I use locking bananas or spades and that works just fine. Any solution that won't come off and accidentally and short the opposite terminal if ever comes loose. I always tend to stay away from oversized or to fancy terminals, the more discrete and minimal the better.
Answers
Spade on speaker.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
Why does this have to be so hard.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Bare back
Done! F1Nut/slbenz had the best answer
I'm surprised no-one mentioned SpeakOn yet...
