Installing Larry's rings on the PR
How do you install the PR ring , if they are suppose to be on the inside? What is my feeble mind missing? Also, do you just put the foam behind the mid drivers and not on the top or sides ? Thanks!
  • Do you have to unbolt the bottom piece ?
    F1nut Posts: 51,766
    The PR ring has two slots cut out. You bend the ring at those two spots just enough to slip it through the cabinet hole, then bend it back flat.
    BH5 or the like goes just behind the mid-drivers.....didn't I already spell that out to you?
  • I sure don't see any slots on mine. Yes, you did spell it out. Thanks!
  • MrBuhl
    MrBuhl Posts: 2,419
    As I recall, mine just had two black marks on opposite sides, it bends very easy over a straight edge.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • machone
    machone Posts: 1,559
    Mine did not have slots. But as mentioned above I just flexed it into the cabinet.
    One thing to note is that I did have to reduce the height of the threaded inserts so that they set below the surface that the passive seats against. I did this with a belt sander.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • I sure was over thinking that one. One side all done. I'm sure the other side will take much less time.
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ haha! ^^ I remember thinking the same thing!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
