fx300i to replace RT25i surrounds?
Jimbo18
Jimbo18 Posts: 2,348
Local CL has a pair of fx300i's for $80. Would they be a good upgrade over the RT25i's I am using as surrounds in my HT? I haven't heard fx300's.
If I decide to sell the RT25's, I figure it's probably a wash on the cost.
  • rooftop59
    rooftop59 Posts: 8,121
    I haven't heard the fx300is, so take this with a grain of salt. My only thoughts are that the tweeters in the fx300is don't match your setup, and that the rt25is are great speakers that throw a pretty wide soundstage, so I don't know that you would gain much with the dipoles. I think you would gain more by getting a little more power behind them, but obviously that's a different issue altogether.
    Game Room 5.1.4:
    Bedroom 2.1
  • Jimbo18
    rooftop59 wrote: »
    Yeah, I know I need more power. Been hoping to step up to a Pio Elite but can't do that yet. Food and shelter a bit more important right now.
  • rooftop59
    Didn't mean to force that issue man, with four youngins I totally get it. Mainly saying that I think if I were you I would stick with the rt25is fwiw...
    Game Room 5.1.4:
    Bedroom 2.1
  • Jimbo18
    No offense taken, I agree with you. Just thought, since I have never heard the fx300, I would ask in case they were a big step up in ambient sound.
  • scubalab
    scubalab Posts: 3,105
    Jimbo,
    The FX speakers do have a different sound to them and work best (in my experience) in surround duty on side walls. I'd agree with Paul though that the RT25i's are great little speakers. I picked up a pair on his recommendation recently and love them. If you're using them as rear surrounds, I'd probably keep them over the FX's since the tweeters are a match for your other speakers. As far as side surround, the dipoles do a great job 'surrounding' the listener with sound. Hope that helps...
    -Al
    tonyb Posts: 33,068
    The FX's were built for ambient sound and a wider field, if that's what your shooting for. Yes, they will sound different than the 25's, but in a good way. Sounds will come from areas of the room that will have you turning your head to look.
    Comes down to a matter of preference is all. I think you'll dig them.
  • rooftop59
    My main point is that the tweeters don't match. But yes, all things being equal I the soundstage should be wider...
    Game Room 5.1.4:
    Bedroom 2.1
  • Jimbo18
    Thanks, guys. I don't have a setup where I can use side surrounds, so the RT25's are in the rear. I guess I will stick with that.
    I really like the little bookies and have tested them out as fronts and, other than bass, they perform very well.
  • rooftop59
    That series (RTxxi) is my personal fav in the rti line, and the RT25is are my favorite of the series. I think you have a nice, easy to drive setup there...if I had the space, I would have rt55is in my HT, but alas the wifey say NOGO!
    Game Room 5.1.4:
    Bedroom 2.1
  • Jimbo18
    rooftop59 wrote: »
    Thanks. I picked up the speakers off CL over a couple years after reading comments about them on this forum. Unfortunately, I got the Yamaha receiver before I joined here, otherwise I would have something started with something else.
