Resistors to install SDA IIb
I know I ask a lot of questions here but I am still trying to learn. In the tweeter circuit of the SDA IIb speakers I installed Mills 0.5 Ohm resistors as I took that suggestion early on to replace/remove the polyswitch. So, as I put in all the new capacitors I noticed something I forgot. I still have sand resistors in the circuit. As per the diagram I have for the IIb speakers it list these resistors as 2.7 ohm. What should I do to replace these ? Try and find 3.2 ohm Mills and just put those in or buy 2.7 ohm Mills and add them ? Sorry its late and I am a bit confused as to what I should do. Thanks
    F1nut Posts: 52,103
    Just get the 2.7 ohm Mills resistors since you already have the 0.5 ohm installed.
    BTW, it would help everyone if you used the proper model name, it's SDA 2B
  • Nightfall
    Nightfall Posts: 10,083
    I keep thinking you bought a pair of SDA Infinity's :D
    afterburnt wrote: »
    Village Idiot of Club Polk
  • VSAT88
    VSAT88 Posts: 1,367
    Will do, SDA 2B. Thanks.
    F1nut Posts: 52,103
    B)
