polk hinge problem
I ordered a pair of the polk hinge in black and silver off of woot last week and got them in the mail yesterday. I like the fit and finish and have heard good things about them. But when I hooked them up sounds was staticy and intermittent in one ear. Not sure if it was the cable that was defective or if it's the earphones themselves. I contacted woot and they don't have any left in stock to replace so my only option with them is a refund. I am wondering if polk might warranty these (either repair or replace). I really want to keep them especially at the price I got them. Anyone know if polk repairing or replacing is a possibility or am I only looking at a refund from woot? I suppose I will try customer service when they open.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
    gudnoyez Posts: 8,166
    Wiggle the cord at the base of the right cup and see if that makes a difference and gets rid of the static. I got a pair no problems, got a second pair and it had that same issue but after doing that the problem went away and has not returned.
  • shawn474
    shawn474 Posts: 3,052
    Thanks. I will try that. Apparently woot is not an authorized seller so I am SOL. Either refund from woot or nothing. I would like to try another cord but it isn't a standard headphone jack......
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • The new cables can be kind of tight, so make sure you have it pushed in all of the way, and on both ends.
  • shawn474
    Yeah I tried the plug and the wiggle test. Nothing worked. just going to send them back for a refund. But looking on Amazon, polk is offering the buckles and hinges for less than $45........and free shipping. Actually going to save a few bucks and upgrade to the buckle
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    Got the buckles today and the packaging was nice. I unboxed them and hooked them up. Just like someone mentioned, the static occurred after hooking them up but twisting the cord a bit took care of it and after about 2 hours of listening has nt returned. They sound great and are pretty comfortable. They do get a bit hot after extended listening. All in all, for what amazon is charging, I don't see how you can get a better pair of over the ear headphones for less than $45. I do wish the controls worked with my android phone but not a deal breaker in the least.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • scubalab
    scubalab Posts: 3,105
    Shawn,
    My daughters each have a pair of Hinges, and I have a pair of the Buckles. With one pair of the Hinges, we had a similar problem (one side would not play unless you forced the cable sideways and held it there). Since we had two pairs, I swapped cords and confirmed the issue was in the headphones and not the cord. I called Polk, and they said send JUST the headphones to them. Even though I bought them dirt cheap on clearance (but new) from Cowboom they honored the warranty (maybe because Cowboom is a Best Buy company...). They replaced the headphones with a pair that works and we haven't had issues since.
    Nice grab on the Buckles. I like them, but they do get a little uncomfortable after longer sessions and your ears do get warm! The bass is a little heavy on them, but not artificial sounding and overwhelming like Beats. Enjoy the new cans!
  • D2Lo
    D2Lo Posts: 352
    Thanks for all this feedback guys. Sending to the engineering team to make sure this isn't a reoccurring problem.
