Rotel RB1095 can't handle Polk 707?
nhhiep
nhhiep Posts: 877
Do the 707s drop to 2ohm or something to shut down the Rb1095 when cross at 40-60hz?
Last weekend, at a house party, I crossed the 707s at 60hz with SVS SB13U. Volume is fairly loud at -10dB on the Denon AVR 3808. After a few hrs, the rotel went into protection mode, even though it's sitting on the floor with room temp is 70 degrees and only used 2 out of 5 channels.
It was an embarrassment to see your system died in the middle of the party. I took out a cheap Crown XLS 2500 pro amp to replace the rotel and the party went on for another 4-5hrs w/o any issues.
Anyone experienced problems with Rotel+Polk LsiM combo?
  • pearsall001
    pearsall001 Posts: 5,400
    nhhiep wrote: »
    A properly functioning RB-1095 wouldn't even break a sweat running the 707's fullrange let alone with them crossed over at 60hz. I sounds like you might want to have it looked at or the only thing I can possible think of is that maybe after hours & hours of such loud playback that it might have had enough & needed to take a break. That might be the case for pretty much any amp pushed way too hard. Don't your ears hurt???
    pitdogg2 Posts: 27,918
    A properly functioning RB-1095 wouldn't even break a sweat running the 707's fullrange let alone with them crossed over at 60hz. I sounds like you might want to have it looked at.
    I have to agree here. I have seen the Rotel push some very inefficient speakers that dip very low..
  • nhhiep
    nhhiep Posts: 877
    the rotel is like new and actually can run all day if cross at 100hz. I tried that a few weeks ago but wasn't happy at 100hz cross.
    my only guess is the rotel just can't handle the 707 near full range for a long period of time.
    to my surprise the crown sounds the same and runs cooler.
    F1nut Posts: 52,406
    The 707's are 8 ohm nominal and are a very easy load.
    The amp being like new means very little. Crossed at x means very little. Volume at -10dB means very little. How it performed previously means very little. Electronics fail at any given time for any number of reasons.
  • nhhiep
    nhhiep Posts: 877
    edited February 2016
    is it me or the guy above sounds like a smartass? in my case, crossover hz is the difference between on and off.
    or maybe I need to use another power cable? :)
  • Dennis Gardner
    It is evident that something is wrong with the amp. Simple as that......have it checked out, the shutdowns are a warning signal. That amp should never act like that.
  • Nightfall
    Nightfall Posts: 10,083
    nhhiep wrote: »
    It's just you. His statement is sound.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • SugarmillMan
    I agree that something must be wrong inside that amp.
    I previously had two Rotel amps that powered speakers much harder to drive than those are. Never had an issue. Rotel has historically been a maker of solid equipment.
    I'd have that amplifier professionally serviced.
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • Emlyn
    Emlyn Posts: 4,920
    Rotel stopped importing new RMB-1095 amps around 2006, so they are probably around 10 to 15 years old even if they do look like new externally. Time may have caught up with it. Rotel tended to use good but not great component parts in their amps and built them to a price point. If the amp was bought used, there's no way of knowing what previous owners did with it that may have heat stressed the internal parts. I also remember Rotel amps to run fairly cool because of the large heat sinks and operation class, even when run hard. I used to use Rotel products with the older 4 ohm LSi series speakers, which present a more difficult load and were solid performers for me. When functioning normally, the RMB-1095 should have no trouble with any five of the LSiM series run full range without a break. Also, I don't think the -10db volume level on the receiver is unusually loud in stereo mode.
  • Joey_V
    Joey_V Posts: 8,606
    I doubt it would have trouble. 1095 is basically a multichannel 1080.
    nhhiep wrote: »
    to begin with the Rotel is still sending out a full range signal to the 3808, the 3808 is handling where that signal is going to go....correct?
    nhhiep wrote: »
    You have that signal path backwards bro. The Denon is filtering out the signal, sending whats crossed over to the sub and amp, then on to the speakers.
    Regardless, I'd echo what everyone else has already said. Something is up with the amp because that should handle the 707's with one hand tied behind it's back. That or you had some stray wires touching in the binding posts causing it to go into protect mode.
  • Emlyn
    Emlyn Posts: 4,920
    If the amp was sitting on the floor on carpet or a rug, the protect mode could even have been triggered by a static discharge in the system if it was a one time thing.
    tonyb wrote: »
    nhhiep wrote: »
    well that is what I get for thinking early in the morning......
    carry on....
    F1nut Posts: 52,406
    Emlyn wrote: »
    Very good point.
    Also, if on carpet it would have restricted the movement of air up and out of the heatsinks leading to overheating.
  • nhhiep
    nhhiep Posts: 877
    the amp was sitting on floor wood all the time.
    I couldn't tell between the Rotel and Crown, but last night my wife mentioned that the Rotel sounds better. I asked her how and she said she couldn't explain.
    I guess I've to fix the Rotel, but not sure how since it only fails in a specific condition.
    Static can exist on a wood floor too....it's called dust, and static lives there. Good ears your wife has btw. :)
    Take it to a local tech, tell them the problem your having and to give it the once over. Looking for any cracked or broken solder joints, bad resistors/caps and that everything is performing up to spec.
  • nhhiep
    nhhiep Posts: 877
    Interesting thing I found last night while pushing the 707s full range is that the bass is not that clean. it just dragged on too long. reminded me of the clubbing days when I was young.
    Crossed it at 60hz to let the SVS SB13 took over and much better result.
    why didn't polk make a tall 703? or sealed 707 without the woofers?
  • RamZet
    RamZet Posts: 792
    call Rotel and send it to them. There will be a $150 bench fee plus parts. If they find nothing wrong with it you still have to pay that -150.
    Do you have another set of speakers you can test the amp with?
    If its a 5ch amp why dont you use 4 of the 5 to power the speakers, assuming your speakers have four post?
    B&W CM9Classé Sigma
    nhhiep wrote: »
    Something sounds off to me. Sounds to me like your over driving them or something is off kilter in your settings.
  • jeremymarcinko
    I have sent an amp into protection momentarily due to static, just by touching the pre with my shoes on.
    heiney9 Posts: 25,724
    Funny, I discharge myself on my amp before I touch any other gear. It can take a direct short so a little static discharge ain't nothin'.
    EndersShadow Posts: 17,765
    heiney9 wrote: »
    Brock.... Do you wipe it down after discharging on it? I would hope so!
    txcoastal1 Posts: 13,520
    heiney9 wrote: »
    You owe me a new phone screen Dan.....
    That shite funny....
    Damn, that sure was worded the wrong way!!!! But it sure was funny!
    To clarify; Before changing the volume on the pre, or anything else if I know it's a static situation I always touch the amp first before any other component to discharge the static electricity. It's become almost muscle memory in the Winter time to do this.
    P.s. The Aleph is impervious to a direct short, needs/has no protection circuit, is built like a tank.........so I am NOT suggesting that others follow the above procedure. Just saying what I do in that situation.
  • nhhiep
    nhhiep Posts: 877
    edited March 2016
    finally sold it for 1000. now looking to spend that money on another used good sub like svs or jl. maybe another sb13u to match the other. bought the current sb13u used for just $700
  • polkfarmboy
    polkfarmboy Posts: 5,703
    You sold the amp that has problems dor $1000? Better hold onto that 1k if you did, especialy if they paid with paypal!
