Preamp Tubes Lots Of them.
13»
    heiney9 Posts: 25,419
    edited February 2016
    If you would, keep an eye open for a Raytheon 5814, black pinch plate, 3 mica, square getter with 3 vertical holes in the plate (you can see the grid rod). It looks like the Raytheon 5814 gray plate windmill getter.
    I have a single looking for a mate.
    Looks like this, square or halo getter.
  • lightman1
    lightman1 Posts: 10,796
    You guys are geeks.
  • hochpt21
    hochpt21 Posts: 5,423
    lightman1 wrote: »
    You guys are geeks.
    LOL!! :D
  • ken brydson
    ken brydson Posts: 8,988
    Wish I knew WTF they were talking about... Nevermind, don't need another rabbit hole.
  • ecod123
    ecod123 Posts: 379
    My guess is he got Mullards..............but perhaps he'll chime in.
    Hi Brock,
    I will definitely take some pics and post them when the tubes get here. I did not know that these Amperex could be so interesting. Hopefully the pics will help with identifying them.
    I got the Amperex & RCA black LP because the Telefunkens were taken. I wanted to try long plates in a restored vintage Magnavox amp I bought.
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    I will keep an eye out. Here is a pic of a fairly rare Side D getter Sonotone 12AX7 and here is a pic of a Mazda grey plate but it does not have the hole in the plate.
    Regards Snow
  • haimoc
    haimoc Posts: 1,031
    snow wrote: »
    heiney9 wrote: »
    Ok, I'm mulling it over along with the TFK 12AU7. As a rule I don't care for TFK's as they tend to sound lean and a bit thin in my rig, but I do love the air they can have.
    The EE Minimax allows me to mix and match a 12AU7 pair. I've heard good things pairing the TFK with a lusher black plate tube. It takes away the lean tendancies but retains the wonderful air TFK's are known for.
    I told myself I wasn't buying anymore tubes as I have enough for several lifetimes, but............
    Welllll...... If it helps you decide The teles were made in the late 50's and test great 3600/3800 and 3800/3600 where 1560 is minimum good the Silvertone mazda tests at 1700/1900 where 950 is minimum good here is a quick pic of the three.
    Regards Snow
    I am interested in the matching pair of TFK 12AU7 (The two on the left of the picture).
    Are both tubes of this pair matching 3600/3800? Thanks.
    Snow no need to hold those TFK;s if you were. Let Hamioc have them.
  • haimoc
    haimoc Posts: 1,031
    heiney9 wrote: »
    Thanks H9.
  • snow
    snow Posts: 4,358
    haimoc wrote: »
    snow wrote: »
    heiney9 wrote: »
    Regards Snow
    Hi one tube reads 3600/3800 and the other tube reads 3800/3600 roughly a 5% difference between sides and tubes. These came out of a Ampex reel to Reel recorder from a console made in 1959. Thanks Brock
    Regards Snow
  • ecod123
    ecod123 Posts: 379
    H9,
    here are some pics of the pair of Amperex 12AX7 LP. Hope the pics help in determining the identity of the tubes. If you need more or better pics, let me know.
    If the codes on the tube boxes match the codes on the tubes, you did well. The delta triangle means Heerlen Holland and the mC6 code is the very last change code for long plates.
    Sweet tubes for an excellent price, in fact sorry I missed grabbing these....lol :D
    Enjoy!!
    Also since they are Holland made they won't have halo type getters, but D getters with a flat bar across or in the case of very early ones, they may have a bent square getter.
    You did good on these as the Holland LP ECC83 is very desirable and expensive. I sadly don't have a pair of the long plates because I am not willing to pay the high prices. I have yet to find a reasonably priced pair in all my travels.
    These were inaccurately described as being halo's, otherwise I would have jumped on them right away!!! You won't see a long plate Holland tube with a halo getter. :DB)
    Great get on those. Sort of jealous :)
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    Lol. Yes I marked them wrong on the boxes that's what happens when you do too many too fast, If you double click on the 2nd picture provided by Ecod you can clearly see the delta code and 9A
    Regards Snow
    It happens, I meant your sales description was mis labeled as having Halo getters is all. The only Amperex labeled lp halo's would be Mullards made or even Siemens, but those are usually a double post.
    I skimmed right by them as I have plenty of pairs of Mullard made LP's. If it had said D getter's w/flat bar I'd have been on them......lol.
    :D
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    :D
    Yes you are correct on all counts, when you first mentioned it I was starting to wonder if they were actually short plates instead of long plates or what have you. The mystery has been solved and he got a great deal but that's ok he's a good customer and deserves it :)
    Regards Snow
    I'm glad they went to a fellow Polkie. Lord knows I've had my share of great deals. It just never seems to work out for Holland LP ECC83's.....lol.
    But as a consolation I have a pair of the 50's Mazda Silver plates, LP Valvo Hamburg, LP Mullard Blackburn and Raytheon 5751 3 mica BP, windmill getter and 40's Tung Sol long BP's.
    So it's not like I'm hurtin' for good sounding tubes :p;)
