Can you swap RT25 tweeter with RT25i?
I thought I read somewhere that you can directly replace the rt25 ( I think it's the SL 5507) with the RT 25i tweet ( not sure the model # ). I was going to look for a replacement for my RT25 & figured might as well upgrade them while I'm at it. Thanks
- L200 Legends (Black Oak)
- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- CSi A6 Center (Cherry)
- Pioneer SC-1222K (7.1 AVR)
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 (5.2 AVR)
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG
  • rooftop59
    rooftop59 Posts: 8,120
    Did the 25s have the black silk dome tweets? In either case, the answer is yes you can, but I don't know if the crossover values changed. I actually replaced the silk dome tweets in a pair of rt15is with the tri-lam domes from rt25is since I much prefer the tri-lams, and it sound much better to my ears. They are, however, outdoor speakers (under a covered patio) and do not receive any critical attention. So take all that with a grain of salt...
    Game Room 5.1.4:
    Bedroom 2.1
  • TCK
    TCK Posts: 231
    edited February 2016
    rooftop59 wrote: »
    Did the 25s have the black silk dome tweets?.
    Yes, they are black. I attached a pic. Thanks for the info. I thought the crossovers were very close if not identical but I could be wrong. Seems like an easy & obvious upgrade
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • rooftop59
    Yep you can switch them out. Its only an upgrade if you like the tri-lams better, which I do.
    Game Room 5.1.4:
    Bedroom 2.1
    heiney9 Posts: 25,583
    I compared the RT20 xover to the RT25i (no RT25 x-over is posted) they are quite a bit different. It uses a 2nd cap in the tweeter array and a very large cap in the woofer section.
    I'm sure they are physically the same, but the older "black" tweeter is a different material than the "silver" tri-laminate used in the RTxxi series. I'm sure they are electrically different. How that affects the sound is anyone's guess.
    Why not just replace with correct parts or buy a pair of RT25i's?
    I guess my point is on the RT20 they use a cap and resistor in parallel in addition to another cap in series for the tweeter.
    The RT25i, they use a single resistor in series with a high value electrolytic cap, bypassed with a mylar cap in parallel with said electrolytic cap.
    Two very different approaches, so I'd say the tweeters aren't all that compatible to each other.
    rooftop59 wrote: »
    What are you basing this recommendation on? Just that they physically fit?
    The RT25i uses the SL 6505 or 6506 tweeter, IIRC.
  • rooftop59
    heiney9 wrote: »
    rooftop59 wrote: »
    I know nothing about the crossover components, so I won't pretend otherwise. But the rt20 and the rt25 are VERY different speakers. RT20s have two 8 inch woofers and the first tri-lam dome tweet, the rt25 has one 5.25 woofer. The RT25 is the same configuration as the RT25i, the only (visible) difference is the black silk dome vs silver tri-lam, and the gray vs blue woofer. As with the rt55 v rt55i, there has been much debate as to whether there were any changes in crossover, and I do not know.
    My suggestion is based on sound. I have done the same thing myself and prefer the sound of the tri-lam tweets in those speakers.
    Game Room 5.1.4:
    Bedroom 2.1
    The RT20 (not 20P) schematic only shows a single woofer. I couldn't remember if it was a bookie or floorstander.
    So you have done the swap yourself, so then that's where the advice is coming from, cool beans.
  • TCK
    TCK Posts: 231
    heiney9 wrote: »
    I thought the RT25i had a better tweeter. It's the same concept as replacing a SL2500 with RDO-198. If it's not a direct swap, then I will just replace with an RT25 tweet.
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • rooftop59
    TCK wrote: »
    heiney9 wrote: »
    It is, I have done it, I say go for it!
    Game Room 5.1.4:
    Bedroom 2.1
    If someone has successfully swapped them, then go for it. I was just playing a bit of a devil's advocate. If I really think about it, they are probably a close match. Still if it were me I'd look at the crossover values of the two models and be sure there aren't any huge variations.
  • TCK
    TCK Posts: 231
    Thanks H9, I do appreciate looking at all angles. I would hate to put them in only to find they don't work right. I think I will call cs & see if the replacement is the same for both models. May have to go that route & just get new ones. They can't be that much, there is not much to them. They have a magnet the size of a few nickels stacked together
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • rooftop59
    FYI, I have two SL6501s that would work in these. They are a bit discolored but work fine. I would ship them for $35 if you are interested. You could see if you like the change for not much dough...
    Game Room 5.1.4:
    Bedroom 2.1
  • TCK
    TCK Posts: 231
    Very generous offer @rooftop59. These are my daughter's & here's the thing...she is happy with them. She doesn't understand why I want to mess with them & I agree, they do sound ok as is. The reason I was looking for a replacement tweeter, is that when I was listening to them one day, I noticed one tweeter a tad bit quieter than the other one. I took it out & swapped it out with the other one & the problem followed over to the other speaker. I figured I might as well upgrade as I said before.
    So I will take them, thank you. She never takes the grills off anyway.
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • rooftop59
    Sounds good, shoot me a pm and we'll get it worked it.
    Game Room 5.1.4:
    Bedroom 2.1
