Yamaha CA-810, Any good?
I have a shot at a CA-810. I'm currently have a CR-800. Would the CA-810 be a significant improvement over the CR-800?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
    pitdogg2 Posts: 24,623
    20watts give or take....me I donno it seems to be a wash except on the eyes 810 looks more stylish
    http://www.hifiengine.com/manual_library/yamaha/ca-810.shtml
    http://www.hifiengine.com/manual_library/yamaha/ca-800.shtml
  • Easy Runnin
    I have the CR-800 not the CA-800. Receiver verse integrated amp. Slightly different. The CA-810 also has MC and MM on the phono. I don't really needed it but for the asking price of $125 it has my curiosity.
    mhardy6647 Posts: 33,078
    edited February 2016
    The CA-810 is a nice piece, sexy meters, good sound... but I'd opine that it is not an improvement per se over the CA-800.
    The CA-800 is a tad better built (IMO) and it has the big added advantage of selectable operating Class A output bias. Now, if you don't, or can't, take advantage of this feature (e.g., your speakers aren't sensitive enough for good performance with ca. 15 watts per channel), the playing field will be more level. The CA-810's definitely prettier ;-) and a bit more powerful -- but I still think the CA-800 is a marginally better amplifier.
    I have a CA-800 and I like it a lot.
    Ooops, the OP's got a CR-800. Yeah, it's probably a minor upgrade over a CR-800, since it's "only" an integrated amplifier and it's a bit more powerful. I wouldn't expect a substantial increase in performance from a sound quality perspective.
    You might want to keep your eyes out for a CR-1000 or a CA-1000 (integrated amp) for a deliberate "upgrade" from the CR-800. The former's funky-looking but quite nice. The latter is a very fine if cosmetically understated integrated amplifier.
    EDIT:
    Other "upgrades", I'd opine, might be a CA-1010, CA-2010 or a CR-1020 or CR-2020.
    The CA-810 really is nice, but it's kind of neither fish nor fowl. One nice thing about the CA-810 is the power amp and preamp sections can be used separately (e.g., one could try a different/better preamp or power amp if one were so inclined).
    FWIW, photo of a CR-1000 (and a CR-820):
    14476943406_1a372b8e5a_b.jpgDSC_6691_ by Mark Hardy, on Flickr
    I've gotta say: a CA-810 in good working order for $125 would be an excellent deal, it seems to me.
    I'd forgotten that there was a LOMC input on the CA-810 :-P
    FWIW, I've never tried the (LO)MC phono inputs on any of the Yamahas here that have one... but I wouldn't set my expectations too high. These are active circuits (multiple amplifier gain stages) with a lot of gain. Might be kind of grainy/noisy/not great sounding. It is safe, methinks, to assume that the performance of the MC section in a mid-price 1970s component (which the CA-810 was) would easily be bested by almost any decent quality modern standalone high-gain phono preamp, or a good SUT feeding a decent MM phono stage (e.g., the one in a CR-800).
    All just opinions, of course!
    EDIT: Just looked at the CA-810 OM -- actually, the variety of MM phono load options on "Phono 1" plus the MC option for "Phono 2" might be enough to swing the needle in favor of the CA-810! If and only if the OP is interested in/uses a rekkid playa connected to a Yamaha component.
    Those Yammies always look good. I have a CR-800 as well, and with a pair of ADS L-520s you've got one heck of a good sounding low cost starter that can run with some of the bigger boys!
  • Easy Runnin
    Seller has the ca-810, ct-810 and a pair of Kef 304s. He claims they have been in storage since 1987.
  • Nightfall
    Nightfall Posts: 10,073
    It's not good for capacitors to sit unpowered in a non climate controlled environment for 29 years. Worst case, magic smoke. I wouldn't hook it up to any speakers that I cared about at the least. I'd probably give it straight to a tech.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Easy Runnin
    We are going to use his legs. He claim its hooked up and working fine
  • Easy Runnin
    Man, I hate it when a seller on CL says he'll sell you something. Then he sells it to someone else before you get there.
  • Nightfall
    Where are you located? I have a CA-1010 that needs to be looked at by a tech.
    afterburnt wrote: »
  • Easy Runnin
    Philly
  • Nightfall
    That's a bit far. I worry about shipping vintage equipment.
    afterburnt wrote: »
  • soundfreak1
    soundfreak1 Posts: 3,388
    From my research yamaha put a lot more quality in the power supply and the front end as well in their integrated amps than their recievers (as a design) and we're marketing the integrated amp to a more upscale buyer. ( the more you stuff inside a box the more potential for compromise by the bean counters to reach a price point. ) This is a generality I know but it has a long history of fact behind it. I will say that yamaha made less compromises (in general) than say the mass merchandisers IE pioneer, technics, ect. But never the less this should be factored in when answering your question.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • soundfreak1
    Nightfall wrote: »
    A good tech should have a " variac" to slowly power up the unit first as opposed to just slamming the power supply with 110 cold.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    I love the word "variac", sounds like a machine ready to take over the world. Think Colossus the movie and the Guardian! Alpha 60?
  • soundfreak1
    Or the "KRELL"
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
