Powerstrip help
So I'm looking for something specific. I have a APC H15. I have a couple items that need wallwarts that are large in size and end up blocking ports on either side of them.
I'm looking for a powerstrip that I can connect to my APC H15 to connect all the wallwarts to so I can free up space on my APC.
I've heard you dont want to piggy back a surge protector on a surge protector, so I'm looking for something without surge protection, and hopefully on the cheap side. Dont need it to be super long either.
Anyone know of a decent product that would work for that?
I'm aware of the Furman PlugLock-PFP, but its got a breaker on it, so I "think" its out. The Audioquest powerstrip but I dont think its setup to work for my wallwarts well either so its out.
Would love some other options.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • Nightfall
    Nightfall Posts: 10,083
    Those are all close together though, one wall wart would block two more outlets.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Mikey081057
    But you have 10 outlets ... enough for all the wall warts.. and get them off the APC...
  • Mikey081057
  • Nightfall
    Those are neat, you could plug two wall warts into the same outlet.
    afterburnt wrote: »
  • Mikey081057
    I am not sure I would worry about piggy backing a surge protector to plug my wall warts into would cause me any loss of sleep tho.
    msg Posts: 10,510
    I'm just using those 1ft mini-extensions that Mike linked above for situations like this. There may be some quality ones available.
    There's also the Power Squid idea. I haven't looked around enough to see whether they're available in power strip form only, without surge.
    EndersShadow Posts: 17,732
